Hi Guys,
Im trying to reduce the load and increase the cooling on my RB26 as much as possible. I have already fitted oversize pullies to it, taken the air con off, and am thinking about converting the cooling system to an electric water pump by davies craig, and twin thermo fans. I already have a Aluminium radiator.
The car will mainly be used for street & track work, but i plan to drag it as well.
Has anyone here fitted an electric water pump to their car or have thermo fans? What was your experiences, likes, dislikes etc.
Cheers
Ross
https://www.sau.com.au/forums/topic/64050-electric-water-pump-thermo-fans/
i have one thermo fan (nothing else) on my car which blows onto the alternator. Only time it ever over heats is on those 35 degree and over days. I think with the alloy radiator and 2 thermo fans it should be sweet.
Dunno if that helped you...
P.S - My car is an s13 w/rb20t using the ca18t radiator, there is also a 76mm thick FMIC blocking the radiator so id say it does a pretty good job.
A friend is running this water pump on a 350rwhp+ turbo datto 1600, with large aluminium radiator and twin 10inch thermos. Nothing but good reports. In bad traffic on the really hot days the temp will get hot, but not over heat.
I was keen on reading a review of the Davies Craig water pump about three years ago in Autospeed, but before the article came out, Davies Craig threatened legal action if the story was published.
So what was the deal there?
I guess what i want to know if they are reliable in a high HP situation, where there may be alot of heat generated during the track sessions, and what sort of load effect does the water pump / fan have on an engine.
Cheers
Only 7.5amps it says on the site. I thought it would be a bit more as thats only 90W at 12volts.
But team this up with a big thermo & you'll soon find out how good your alternator is.
I just want a decent thermo as my clutch fan shat it's self.
ylwgtr2 has put together a good twin thermo package on his GTR using falcon twin thermo's and a custom temp switch.
Also I recall Sydneykid has nothing nice to say on the DC electric water pump. I recall the dispute Autospeed had with DC over the pump so my personal choice is to avoid it.
i have a pwr alloy radiator with a 16in thermo and its never gone ova 80 degrees even on the dyno taking off the factory fan will take the load off the wp with an electric water pump if it fails youll boil your engine .if only your thermo fails anything ova 60kph it wont matter
Hey I was looking at an alternative to both ! I'll bounce it off you guys and see what you think. I've owned and built a few engines over the years and was always chasing every bit of horse power I could get for free. Seen some interesting ones over the years.The most memorable being a fan driven altenator. But I digress. I looked at drving the standard water pump electricaly and finally after seeing a fan on a Lexus V8 got me thinking. You see the fan on that engine is drive by a small hydrolic pump through the power streering pump. So I wanted to try and use this pump to drive the water pump itself as the power steering pump runs any way. I dont think the load would be much higher so you might get some free horse power from this set up. Just a bit of food for thought and if I run across one of those fans in a wrecking yard I might give it a go
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
