few simple things 1st :O
remember to stay calm, at 1st its a bit nerve racking as you don't really know what to expect, but thats fine.
The officialls will guide you through at each step as well and worse comes to worse do NOT be afraid to ask for their help, that is afterall why they are there.
You initial contact with the track will be the burnout pad, now its debatable how much a burnout helps on street tyres, but a small burnout does help clean the crap of the tyres.
the light sequence is simple, there are 2 white lights at the very top of the christmas tree. Top light is Pre stage, and 1 beneath it is Stage. ease your car forward till the Stage light is lit.. don't be concerned if pre stage like goes out, its ok aslong as Staged light is still on.
Now the light sequence varies from track to track, it could be 1 yellow after the other till green or it could be all yellow at once and then green. I'll base this on the former. There is 1 thing to remember out of all this reaction time has NO bearing on your final 1/4 mile time.
Ok, so the lights drop and the green light comes up.. Make sure your prepared, match revs and clutch to enable the best take off, i find hi rpm and riding the clutch off the line works good for a rwd car, but this requires a aftermarket clutch or the want to destroy your factory clutch, Multiplate and button clutches are a differant story again. Remember, you'd rather wheel spin than bogging down tho as 1 can atleast control wheel spin to a degree with the right foot. ;)
Depending on your faith in the gearbox/clutch I personally flat shift 1st 2nd and 3rd 4th, 2 3 i dont recomment a flat shift as its easier to hit the gate and hear that lovely limiter :O
After that i usually just pop the bonnet on the return run to let some cool air flow in a bit and idle it a touch when back at the pits. Hope some of this has been helpful :)
https://www.sau.com.au/forums/topic/6406-help-me-strip/#findComment-95952
Guest SPOOLIN
Ok the biggest mistake i see ppl make at the drags is the burnout,
most ppl on their first time pull up in the start of the water and do the burnout BUT when they stop their still IN the water and as they drive up to the line the tyres are still wet and ....well....you guessed it they get heaps of wheel spin.
So when you do your burnout make sure your on the last bit of water so you can carry your wheelspin out of the water and keep the heat in the tyres and keep them dry:uh-huh:
Hope this helps:burnout: :burnout: :burnout:
Lee
https://www.sau.com.au/forums/topic/6406-help-me-strip/#findComment-96121
Good advice Lee,
been practicing on the street with your 280rwkw eh? good stuff.
New drag racer. Good on you. Get out there and have some fun.
You will find that the strip is much stickier than the street, so do
your burnout like Lee said, & roll straight up to the lights before
you lose heat in the tyres.Unfortunately, the only way not to bog
down is to use revs & dump the clutch.A word of warning though -
try to keep the revs up, but only bounce off the limiter just before
the ambers start coming down.Otherwise if the starter take his time with the lights you will be sitting on the limiter too long.
Also - use the handbrake & let the clutch out slightly to load up the driveline( take out slack) or you may start breaking stuff.
It will take practice(I'm still learning) so take your time & have fun.
:uh-huh: :burnout:
https://www.sau.com.au/forums/topic/6406-help-me-strip/#findComment-96247
Guest SPOOLIN
I agree with Munro, You with have to be up on boost and keep the engine reving either by slipping the clutch for the first 20ft or by some wheel spin.
Summoner, Most drag cars are RWD and leave the line with big revs ie. Trans-brake or big stally. So what is the difference by using the clutch and big revs?
"but in the end 1 can only learn from their own experiance"
Not true, I have learn't a shit load from other ppls experiences and always value other ppls ideas and opinions.
Lee
*edit* We are talking about a 180sx not a 600 ci torque monster
https://www.sau.com.au/forums/topic/6406-help-me-strip/#findComment-96273
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
