hi guys just a few questions 1 is do all gtie have quad throttle body's, 2  whats a stock gtir do on the strip and on the dyno, whats the best mods to do to them to make them go
A stock Gtir does around 14.2 sec on the quarter and the best mods for them are the same as any Jap Turbo ie FMIC, dump pipe, exhaust, pod filter, ebc set at 1.2 bar, fuel pump, power FC and coil overs should get you started.
The good thing about those cars are that the stock turbo (T28) isnt limited by the ceramic exhaust turbine that skylines are, so you can push them a fair bit harder.
From my understanding all Pulsar Gtirs have quad throttle bodies and solid lifters.
https://www.sau.com.au/forums/topic/64060-nissan-gtir/#findComment-1202825
yes, as posted above all GTI-Rs have quad throttles and a nice steel wheel T28 which is good for up to (and sometimes just over) 180kw at all four.
A stock GTI-R will run anywhere from 14.3 down to 13.8 depending on the condition of the car, and who is driving it. on the dyno a stock GTI-R should make anywhere between 105kw atw up to 120kw atw again depending on conidtion and dyno.
best mod for your stock GTI-R is some good brake pads, good rotors and braided lines with some good fluid too. cause stock GTI-Rs are quick they just don't stop too well if the brakeing system isn't in peak condition. after that exhaust (dump, front and the rest), then some kind of high flow filter or pod with air box and cold air intake. wind up the boost to around 1 bar, and get a front mount if you want. you will now have anywhere between 140 and 165kw at all four and have a car that can do low somewhere between a high 12 and a low 13. NOTE: your clutch may now be on the way out, if so upgrade. now you'll need to make it handle properly so start with a bigger rear sway bar and replace every suspension bush you can think of with some urethane ones. now if you still have money start looking at coil-overs and most importantly get the suspension set up somewhere that knows what they are doing. now you have a very nice street car, but be aware that unless you are going to keep and enjoy it for a few years you will be dissapointed when you sell it. they are great little cars though.
https://www.sau.com.au/forums/topic/64060-nissan-gtir/#findComment-1202836
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
