  • Replies 46
its on this saturday 30 big hp cars (nothing under 400 rwhp)., bikini car wash. etc etc...should be a few big hp skylines i have been told... dyno runs start at 9.30 - 10am i think... and goes all day....see you there...
cheers.
People have been saying they are putting cars on with over 400hp and have sent invitations to certain people.
So Melv, with 411hp, you just scrape in :P
On boost it says that if you want to put your car on the dyno, you have to ring APC and book a spot. It goes from 10 - 6 IIRC.
https://www.sau.com.au/forums/topic/64062-apc-dyno-day/#findComment-1202771
i thought this site is for gathering info off people who know things others may not, whats your problem erin if someone knows they will tell, i know nothing about friggin apc, never heard of them never seen where they are dont even know what is stands for
**** man your always on my back about this shit, is it so hard to just you know, say oh nah sorry rod just big hp cars this time, instead you basicly tell me to piss off and do shit myself
sorry but you always do it
https://www.sau.com.au/forums/topic/64062-apc-dyno-day/#findComment-1205548
:bonk: You've asked where it is, when a quick search on whitepages would tell you exactly where it is, along with a map. It even lists the webpage for APC, with lots of other information about the place, including what it stands for. You've asked if any car could go on, yet the original post specified 400rwhp+ only.
:thumbsup: Mate, no offence, but do you actually read the threads before you post?
All your questions have been answered in one way or another, yet you ask them anyway. Just have a full read of the thread BEFORE posting.
:type: Typing "APC" and "Logan Rd" into whitepages.com.au will tell you every piece of information you could possibly need, as well as details you probably dont need to know (such as where to get the Sensis toolbar!!!!1!11one1 :headspin: ).
https://www.sau.com.au/forums/topic/64062-apc-dyno-day/#findComment-1205603
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
