Just wondering if someone can help me out. I bought an L28E which someone had transplanted into an R30 skyline. Im currently fitting the engine to my 260z and am currently trying to wire the thing up. Thing is, from everything I've seen, the loom doesnt appear to be a std L28E item (from what I have seen of others anyway). Maybe its the L24E item? here is a pic of some of the wiring http://www.classiczcars.com/forums/attachm...tachmentid=7153
I do have more pics if this one does not suffice. Does anyone have any L24E wiring schematics/ECU pinouts?
Cheers
Ray
https://www.sau.com.au/forums/topic/64079-l24el28e-wiring-from-r30/
I've got one, but only in paper form (I could fax it tomorrow). From memory Oz spec R30 and 280ZX wiring is very similar.
Problem with relying on US sites for info like this is that some of the wiring for their cars can be different to ours (ours is usually simpler...)
Just did some searching and came across some schematics for the L24E...
Does it seem like I am looking at an L24E loom though ?
ECU connector looks like L24E type....but then L28E type looks the same....
I have an L24E loom in the garage (as well as a US spec L28E ECU....and a local L24E ECU....I think)
Interesting...there are actually a few different evolutions in the L28 items (especially the US as they had them over a 8 odd year period) so afaik you cant just go switching and swapping ECUs.
EDIT: Yes the ECU connectors look the same, Im more interested in the wires coming from the loom before the firewall. I havent found an L28 loom that looks just like that as of yet.
i would guess that any wires exiting the main loom INSIDE the firewall..ie in the car not the engine bay.....are probably nothing to worry about......could be things like switching the aircon compressor off if the car stalls or something like that...ide worry more about the ones IN the engine bay.
The ones in the engine bay are no worries thus far.
After checking over the diagram some of the ones inside were pretty important. i.e fuel pump relays, EFI relays etc. I think I have most of it sussed out.
Am still not 100% sure what ECU/loom I have. It seems to be almost the same as the R30 from looking at the R30 wiring diagrams, but there are differences which make me wonder.
Hmm.....odd...my r30 computer wiring harness had NOTHING exiting the loom in side the cabin....only reason the loom came in at all was to keep the computer out of the rain....Hence my previous comments
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
