I can never understand why people do this!
If the engine bay looks dirty then use a rag and clean it by hand!
water and electrical connections do not mix!!!!!!!!!
I live on a dirt road. Cleaning with a rag isn't an option.
Besides, other reasons could be oil leaks etc. May have to degrease to find where the oil is really coming from.
There are many reasons to do it. Just gotta do it right so not to harm anything.
High pressure however is a HUGE no-no near engines IMO. If I can get 3 inch of clay of a dirt bike engine that has baked on there, with not more than garden house pressure, I can't see the need for a high pressure hose on a car engine!
Ah I knew I read something on here not long ago.
Here is a guide for detailing your car.
http://www.skylinesaustralia.com/forums/sh...ead.php?t=47397
and http://www.carcareonline.com/viewarticle.aspx?art=4 was one of the links within the thread.
thx heaps for the feedback guyz,
yeh im definately not doing that again.
anywayz so ive disconneted all the terminals and ive let them sit
will that be enough to solve the problem?
btw where is the coil pack? and yes i do have a pod but being the dikwad i am i didnt cover it, how do i fix it?
dude, if u have wet the pod filter. STOP running the car...you want to get all the water out of everywhere first. It seems you have been running it a fair bit, so with a bit of luck it is just the coil packs.
My advice would be to not start the car until you have checked out the things mentioned above.
Do a search on coil pack servicing
Pod filter - I'd disconect it, sit in the sun until it is TOTALLY dry. See if water has gone up the pipe between the pod and the engine, if it has, might pay to remove the pipe, make sure it's all gone.
If you have water in the engine it is a VERY bad idea to be turning it over.
I am used to drowning dirt bikes, but not cars, I would assume it's the same idea, any place that water may have got, check it out, clean it out, dry it out.
On bikes after all that, you take the plugs out and turn it upside down and turn the engine over to get it all out....but I am guessing you don't do that with cars! hahaha (how funny would that be tho..*mental image*)
i know what your saying ? i say there is water traped under your coil packs as ive had the same thing happen to me i just pulled all my plugs out clean the packs with CRC and plugs put all back and done problem fixed ? and while your plugs are out turn your motor over blow any water or moist out of the bores if u have any good luck with things
When cleaning the engine bay a high pressure spray and degreaser, I made sure to cover the air filter with a plastic bag. I forgot to take the bag off afterwards but luckily I remembered just before I drove off. The car would have had a hard time breathing that's for sure.
We used to jet wash engine bays in one of my detailing jobs. Cover the fuse box (if under in the engine bay) and the alarm siren box. Quick flick over with a truck wash canister, then three times accross the bay with the jet wash to form not much more than a mist.
We always left the engines running as it would be hopeless trying to start it if something got wet.
Any idea of quantity of water or time spent purely on the engine bay with the jet wash? Seconds or minutes?
Hope it sorts itself out mate
I would get a high pressure airline and pull all of your electrical connectors apart and blast all the moisture out then spray with WD40 or similar product. Pull the coil packs out and do the same to them. dry your fully sick pod filter and put that back on.... You cant have done much in the way of damage. If the car sounds like it is missing its most likely because there is water in the coil packs and its shorting out... Just be carefull next time you wash...
P.S unless you had the hose on the air filter the engine wouldnt suck in enough water to hydrolic lock the engine so dont worry about that dude.
dry her out and then take it for a good run to get everything hot and the remaining water will evaporate and you be sucking the doors of HSV's and WRX's before you know it..
ENJOY!
  • 2 months later...
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
