I've had a quite a shit year all round this year, but two of the biggest *car related* events being my R33 blowing up its standard turbo late last year... and more recently being involved in a nasty car accident caused by someone else which resulted in the daily driver being written off, leaving us completely carless until I can get my car running again or when the other party pay us for a replacement car - and of course we find one.
I had been intending on getting a larger turbo, but only just recovered from the costs of other crap thats gone down over the last year - so at such late notice the best I could do was buy a turbo comparable with the stock one to get myself on the road. It was brought to my attention that there was a freshly rebuilt turbo from a VG30ET motor available, and that it would be able to be pretty much a bolt up job to get the car up and going again. Sounded like a pretty sweet deal to me, so went with it.
The turbo arrived yesterday - had a look at all the bits and at first glance it was pretty much as I expected, the compressor housing A/R and wheel were visible smaller than the R33 unit but the turbine size was visibly larger. It all looks very clean, and freshly built as I had been advised.
HOWEVER, these are 3 things aren't quite as I would have hoped:
1/ Oil feeds are different to the R33 ones. This isn't that much of a hassle, it costs money but probably worth while doing anyway. I would normally overlook this.
2/ The outlet from the compressor housing doesn't have the flange that R33's have to attach the piping which heads for the intercooler to, pretty much in the r32 Turbo style. Again, not a biggy - that kind of stuff is to be expected when you get a turbo from a different car.
3/ The wastegate assembly is mounted in the factory Z31 (??) dump pipe, as opposed to in the turbine housing!!!
I had no warning for this bit, and would NOT have bought the turbo if this was bought to my attention as I can't afford to pay for the engineering required to work around it. I've never heard of this, and the previous owner never mentioned it. I wanted something I could just bolt on and get the car mobile with (which the person who sold it to me knew) and
I really don't have the money to get an external wastegate, and I'm also going to have to get oil lines made up for it as the oil feeds on the core for this turbo as well as rubber hosing to connect to the compressor outlet. That all makes getting the turbo running a LOT more hassle than it is worth.
I'm not too sure how much luck I'd have selling this off as I'm too considerate to sell it to someone with a Skyline without telling them its going to be an expensive pain in the arse to get running.
I'm guessing I'm clutching at straws - but if I managed to get my hands on a .63 a/r internally gated Garrett T3 style turbine cover would it be something that could be swapped with the one that came with the VG30ET turbo? I can't see why the shaft or wheels would need to be touched, but knowing my luck it'd still fit into the "Too hard to be worth the effort" basket...
The guy who sold it to me has refused my plea to send it back to him for my money back - even though I would have still been out of pocket for freight and he'd be in no different position to where he was before I had it. The turbo has hardly been touched since being in my care, let alone fitted to anything.
Any other suggestions? At the moment I'm $750 out of pocket when I was at a stretch just to pay for this turbo... and still without a running car.
https://www.sau.com.au/forums/topic/64125-help-turbo-nightmare/
Ok, even if you get an internally gated garrett turbine housing it will NOT have the proprietary Nissan 6 bolt exhaust flange that bolts to the downpipe. You will still need to get a special downpipe made up to bolt to the turbine outlet. Not trying to rain on your parade, just warning you. I have a T04E/T3 hybrid waiting to go on my RB25DET because I had to order a flange to fit and have a pipe welded up. The T3 internal gate housings usually have a 5 bolt or 3 bolt exhaust flange pattern and don't come close to being bolt-ons.
-Matt
Getting a downpipe made for the exhaust flange wouldn't be so much of a hassle though - its the fact that there is no wastegate in the actual housing which is causing me issues :(
GCG are in Australia - it'd be hellishly expensive for me to work with them, and unfortunately I've stretched budget to get this far. It looks at the moment like I am pretty much screwed and just have to accept it.
Any chance of pics of the Turbo? I know VLT's have the same wastegate in the dump stlye so tracking down a VLT dump pipe might be the go.Also I've seen a VG30det turbo and it had the same wastegate setup as normal RB's so maybe you even have a VLT???
Its definately not a VLT, because the dump pipe is quite obviously different to the kind you'd get hanging off an RB - but that sounds like a really good suggestion. Are the turbos on the old 2l Turbo R31's any similar in the wastegate setup to the VLTs? The dump pipe from one of those might be easier to find.
pics:
Sorry about the quality of the turbine housing pic - PXT phone struggling with the dark/light contrast.
I'm not a turbo expert but someone on here must be able to tell ya what turbo that is.All RB turbos have the same set up except the R31 GTS-R wich had a T3/T4 turbo from factory and it had a wastegate set up like the VLT and your's.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
