662GDO you will need a fuel system upgrade to run it properly (pump and iunjectors) Z32 afm, you wont need internal work. If i didnt have the GT-RS i would snap this up in a second! Great Buy! Good luck with the sale!
  • Replies 54
thanks, i am running a walbro pump and it seemed to be up to the task pretty good. Might get away with standard injectors and riseing the fuel pressure abit but i didnt want to risk it.
wat mods did you have to the car besides the turbo. i am seriously thinking about this. mines got fmic, apexi power fc, z32 airflow meter,oil/air seperator and intank bosch 040 fuel pump. would it run 17psi safley on those mods with 550cc injectors and bosch 044 pump or will i have to do some internal work.
any help would be appreciated.
thanx will
i was running a wolf with smaller injectors 480cc and standard internals. had no dramas.. you have everything you need there to run 17psi safely probably even more boost if you wanted
well it all bolts on, only thing you need is to make dump pipe with a 4 bolt gt30 flange, if you have aftermarket one now its eay to modify so wouldnt cost much. then all you need is oil and water lines which would cost prob be around $150
it is also on ebay and finishes in less then a day if you would like to bid on it there. starting bid is 2100, so far no bidders
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...me=STRK:MESE:IT
should stil be pretty good, would be abit more laggy then on a 25 but i dont think it would be to bad. would be alot better then say and old style t4 turbo. should be able to get you 250 rwk on a rb20
    • Vinyl paint always ends up coming off interior trim and looking like arse. For the a pillar trims.....just try cleaning them with fabric shampoo? Maybe ditto for the headliner.
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
