662GDO you will need a fuel system upgrade to run it properly (pump and iunjectors) Z32 afm, you wont need internal work. If i didnt have the GT-RS i would snap this up in a second! Great Buy! Good luck with the sale!
  • Replies 54
thanks, i am running a walbro pump and it seemed to be up to the task pretty good. Might get away with standard injectors and riseing the fuel pressure abit but i didnt want to risk it.
wat mods did you have to the car besides the turbo. i am seriously thinking about this. mines got fmic, apexi power fc, z32 airflow meter,oil/air seperator and intank bosch 040 fuel pump. would it run 17psi safley on those mods with 550cc injectors and bosch 044 pump or will i have to do some internal work.
any help would be appreciated.
thanx will
i was running a wolf with smaller injectors 480cc and standard internals. had no dramas.. you have everything you need there to run 17psi safely probably even more boost if you wanted
well it all bolts on, only thing you need is to make dump pipe with a 4 bolt gt30 flange, if you have aftermarket one now its eay to modify so wouldnt cost much. then all you need is oil and water lines which would cost prob be around $150
it is also on ebay and finishes in less then a day if you would like to bid on it there. starting bid is 2100, so far no bidders
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...me=STRK:MESE:IT
should stil be pretty good, would be abit more laggy then on a 25 but i dont think it would be to bad. would be alot better then say and old style t4 turbo. should be able to get you 250 rwk on a rb20
    • Give the fluid a really good flush, then go do the same track again. Report back too please
    • I think most of the benefit there is really from the battery as well, having 1 kWh or so means you don't need the engine running at idle to run the AC, when the battery is depleted you can run much higher idle to charge the battery at a lower bsfc point and then shut it back down, you can regen on braking to recover some of that power too. I can't imagine the benefit from only running the compressor as much as needed is huge if you're mostly only running the AC on hot sunny days where it really needs to work hard to keep interior cabin temp under ambient.
    • Yeah, unless you're doing it by the book, your data is probably not useful. Boiling point drops rapidly with only just a little water in it.
    • How hard are you tracking it? I have 378 in front and 355 in the back with decent pads and my brakes were spongy after a decent session with lots of braking. It was a short track though but got up to around 190-200 max. be keen to hear. Mind you, I havent flushed my fluid so thats probably part of reason.
