662GDO you will need a fuel system upgrade to run it properly (pump and iunjectors) Z32 afm, you wont need internal work. If i didnt have the GT-RS i would snap this up in a second! Great Buy! Good luck with the sale!
  • Replies 54
thanks, i am running a walbro pump and it seemed to be up to the task pretty good. Might get away with standard injectors and riseing the fuel pressure abit but i didnt want to risk it.
wat mods did you have to the car besides the turbo. i am seriously thinking about this. mines got fmic, apexi power fc, z32 airflow meter,oil/air seperator and intank bosch 040 fuel pump. would it run 17psi safley on those mods with 550cc injectors and bosch 044 pump or will i have to do some internal work.
any help would be appreciated.
thanx will
i was running a wolf with smaller injectors 480cc and standard internals. had no dramas.. you have everything you need there to run 17psi safely probably even more boost if you wanted
well it all bolts on, only thing you need is to make dump pipe with a 4 bolt gt30 flange, if you have aftermarket one now its eay to modify so wouldnt cost much. then all you need is oil and water lines which would cost prob be around $150
it is also on ebay and finishes in less then a day if you would like to bid on it there. starting bid is 2100, so far no bidders
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...me=STRK:MESE:IT
should stil be pretty good, would be abit more laggy then on a 25 but i dont think it would be to bad. would be alot better then say and old style t4 turbo. should be able to get you 250 rwk on a rb20
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
