Looking for a CAS (production date 9/97) for my r33 sII rb25det...
I can't help you with a CAS, but I just check FAST and there was indeed a change of the CAS effective 9/97. Anyway, if you can't get one secondhand you might be able to order it through Nissan and the part number you want is:
23731-5L300
Important note: this is the same as the PN for the CAS used on ALL R34 models with RB engines (ie RB26DETT, RB25DET, RB25DE and RB20DE), so that will widen your options.
Also all the Nissan CAS's that I've seen have the PN stamped on the outer circumference, so if you get a secondhand one it should have that number on it somewhere.
Good Luck
