Well my first time back at wsid in about 8mths with high hopes and that's where it ended. My car is now running better than ever and once again I still couldn't grab a decent time, I feel like headbutting a brick wall :(
I did manage to get a new PB but only by literally a bee's dick.
1. 14.489 @ 94.84mph / 2.190sec
It felt nice and smooth, launch was the usual but for some reason I was -way- down on mph, I didn't even miss a gear :D
2. 15.265 @ 100.23mph / 2.737sec
First run after a 30min rain period. Absolutely no grip on the greazy track and simply bagged em up!
3. 14.145 @ 102.07mph / 2.167sec (<- new PB)
Tried to slam the gears harder, felt smooth once again and managed to get a new PB (old PB was 14.163 @ 100.20mph / 2.148sec).
4. 14.252 @ 100.87mph / 2.166sec
Once again was trying to work the gears hard but was slightly slower even though it felt just as good *shrugs*
5. 14.571 @ 98.02mph / 2.184sec
Used low boost this time (7psi) just for shits n giggles (even though high boost is only about 8-9psi haha).
As you can see my launches are pretty much spot on everytime (even though 2.1xx sec is not overly impressive atleast it's consistent). Sure I could grab some semi-slicks or even drag nitto's etc and probably shave off a tenth or 2 but I shouldn't need to when i'm making a solid 195+ rwkw. I'm a good 0.5sec off the pace of where I believe I should be (and the times others are doing in similar powered cars) and im stumped as to what it is (obviously it's the driver).
Was a great nite of racing (besides the rain periods). Some awesome cars about and probably the biggest meeting i've seen in a good 5-6mths. Wish I left my car in the carpark and spectated instead.
https://www.sau.com.au/forums/topic/64153-wsid-9-2-05/#findComment-1203612
i only ended up getting 240RWKW
need to lower compression gonna get a steal head gasget, that will bring her up to the 290 mark.
im gonna buy some slicks soon, just gotta find out how to fit them without removing the brakes, 16" is the only size that can go on.
any1 know where i can get piks from last night??????
https://www.sau.com.au/forums/topic/64153-wsid-9-2-05/#findComment-1203992
mods
td06 20G
Greddy Manifold
HKS 50mm External Wastegate
FMIC
Custom Plenum
550cc Injectors
600HP fuel pump
Nismo GMAX twin plate clutch
Power FC
Q45 AFM
KN Air filter
Sard Fuel Pressure reg
Coming
Head gasget
Forgies
Rods
Cams
Big F**K off turbo
https://www.sau.com.au/forums/topic/64153-wsid-9-2-05/#findComment-1204002
Sorry mate as I've said several times in the past the 20g wont flow enough to make 290 its impossible, maybe some decent drag radials would be better then slicks as then you don't have to worry about the added cost of front runners
https://www.sau.com.au/forums/topic/64153-wsid-9-2-05/#findComment-1204051
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
