Hey i just recently purchased a r33 S1, and am goign through the process of workign out whats been done...
As far as i know it has the following
GCG Hi-flow turbo (happily discovered last night)
Aftermarket dump pipe welded onto a hi-flow cat, and i think 3" exhast thereafter.
HKS Pod Filter
Blitz FMIC
GFB BOV
Turbosmart Dual Stage Boost Controller
Apexi Turbo Timer
Stock ECU
Now I am thinking about upgrading the fuel pump, so i opened up the cover in the boot, and just see a few fuel hoses and sum gland thing.... which everythign goes down into... Do i have to take this gland thing off the find out what fuel pump i have. If someone can enlighten me on this process it would be great, and also how to tell if its a stock fuel pump in there now.
I was also thinking if the car may have injectors? or would this require the mapping of an aftermarket ecu? hence ruling out injectors?
That said I will soon be installing a PFC, and not sure wether i should get the PFC Boost Control add-on... or another after market electronic boost controller, such as an AVC-R? I would prefer to stick with a PFC addon, as dont really want extra gadgets unneccesarily, however am unsure of the accuracey, reliability and the ability for a PFC B-controller to hold boost, and wether boost can be tuned through the rev range with this unit?
Also i want to install an oil catch can some time this week, however all the cans i have seen only have 1 inlet 1 outlet.... i want a 100% plumback can, that i can have easy access to baffle, and require 2 inlets and 2 outlets.. should i just use "T joiners" or will this restrict flow. Am i better of just making my own?
Sorry bout the overly long post... just wishign to clear up a few things i am unsure of... thanx in advance, and please keep the suggestions reasonable... and dont go suggesting i get this and this and that to get 500rwkw.. more than happy to get 250rwkw at the end of the day
:) thanx
https://www.sau.com.au/forums/topic/64154-whats-been-done/
basically u would need some form of management to change injectors so that probably rules that out and the pump also (usually)
the powerfc boost kit offers basic boost control , it does not offer gear / rpm / duty based boost control , auto turbo learning boost control (where you do some 7000rpm runs and it automatically learns your boost curve) , scramble mode or any of the ricey stuff . although this stuff may or may not be usefull to you for the price difference (bugger all) you might as well get the avcr , atleast it can be removed and sold if you have to its not tied to the powerfc and you might want those extra features one day . There is a thread covering this if you want to search
with a powerfc , injectors and pump you should see 250rwkw . the turbo will be the restriction so perhaps plan a slightly bigger fuel system that could support 300+ incase you decide to get a bigger turbo later
https://www.sau.com.au/forums/topic/64154-whats-been-done/#findComment-1203489
thanks for your suggestion, i called GCG turbos, and they said the turbo is good for 260kw and 24psi boost...
but as you said i will require injectors and pump, as i want it to be a reliable 250rwkw...
Should i be leaning towards upgrading fuel lines aswell, and will a fuel regulator be in order?
https://www.sau.com.au/forums/topic/64154-whats-been-done/#findComment-1203496
Your stock injectors will look a purpleish color.
To take the black ring off to gain access to the tank then ur pump u will need a bar and a hammer.Sit the bar a groove then keep beating it counter clockwise untill u get it open.It may take a while but it is by far the only way to undo it.And make sure u put it back on the same way it came off.:)(I used a car jack bar and hammer)
Get into this thread catchcan plumbing question it tells all u need to know,with pics too,about catch can plumbing and will also help u decide what style setup u need.
https://www.sau.com.au/forums/topic/64154-whats-been-done/#findComment-1203501
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
