I have got a R33 GTS with RB20E engine in it. I think the head gasket is leaking as there is oil leaking around the top cover!!!
Anyways..I thought rather than doing any work fixing this engine..I wanted to change it for the RB20DE (get a bit more power with a little loss in fuel economy? (its my daily run around so can't afford the petrol bill of a turbo)
Does anyone know if this engine can be changed in to the my R33 chassis? Will it be a straight swap or do I need to change other things like the gearbox and clutch?
Thanks
Going on holiday for a week soon so thought I'd send my car to the garage while I'm away! :(
https://www.sau.com.au/forums/topic/64183-changing-from-rb20e-to-rb20de/
Might be right about the rocker cover...I'm might be giving parts the wrong name! cheers. My oil pressure fluctuates while driving at steady speeds, could this be due to the loose rocker cover?
And yeah had a chat with my local mechanic...said the wiring probably needs changing and other bits and bobs which would add up to a big labour bill....might aswell get a proper engine put in!
So I think I will try the sealant for now!
Was hoping that it was just a case of unbolting the rb20e and dropping in the rb20de...nevermind. Just happened to come across a crashed RB20de.
Whats the fuel eco of RB25DET? I do 60miles (100km) everyday so i presume my fuel bill will be massive!
Thanks for sharing :thumbsup:
Rocker cover dusnt have any affect on oil pressures... (what exactly are u talking about??)
oil pressue will fluctuate when u apply the throttle accordingly (there is a thread with the
correct oil pressures when idle, and throttle, etc - try a search)
Fuel economy varies as alot of force induced cars have either been boosted or have some form of extensive modification - I am not sure about the stock standard economy you
will have to try a search, or post in the forced induction section.
As for an RB25DE (non turbo) I have managed a bit over 1/4 tank for about 200km
that is about 20~25L driving pretty hard.
theres a big difference in price between a rb25de and a rb25det. If u wanna keep it non turbo then i recomend a rb25de. makes alot more torque. A decent mechanic should be able to do the labour costs for 500-600 i rekon, as this is wat i was quoted to do a rb25NEO in my r33. Bear is mind that other bits might need changin as well so these are additional costs.
Is the RB25DE and the RB25DE NEO-Spec a straight swap conversion? I am aware that
the Neo has a few extras such as stronger internals? and bits here and there...
but things such as wiring? ecu? compression? could you just swap the engine and retain
the old stuff.
Think the RB20E will be able to take a shot of N2O just for fun? or will the internals be a bit weak on this engine?
The oil pressure gauge shows a lower than usual reading every so often at idle and in motion. I know it should change on applying the throttle but the reading doesn't seem to show this.
There doesn't seem to be any performance problems, just the leaking engine.
Whatever, I'll leave that to the mechanic.
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
