I have got a R33 GTS with RB20E engine in it. I think the head gasket is leaking as there is oil leaking around the top cover!!!
Anyways..I thought rather than doing any work fixing this engine..I wanted to change it for the RB20DE (get a bit more power with a little loss in fuel economy? (its my daily run around so can't afford the petrol bill of a turbo)
Does anyone know if this engine can be changed in to the my R33 chassis? Will it be a straight swap or do I need to change other things like the gearbox and clutch?
Thanks
Going on holiday for a week soon so thought I'd send my car to the garage while I'm away! :(
https://www.sau.com.au/forums/topic/64183-changing-from-rb20e-to-rb20de/
Might be right about the rocker cover...I'm might be giving parts the wrong name! cheers. My oil pressure fluctuates while driving at steady speeds, could this be due to the loose rocker cover?
And yeah had a chat with my local mechanic...said the wiring probably needs changing and other bits and bobs which would add up to a big labour bill....might aswell get a proper engine put in!
So I think I will try the sealant for now!
Was hoping that it was just a case of unbolting the rb20e and dropping in the rb20de...nevermind. Just happened to come across a crashed RB20de.
Whats the fuel eco of RB25DET? I do 60miles (100km) everyday so i presume my fuel bill will be massive!
Thanks for sharing :thumbsup:
Rocker cover dusnt have any affect on oil pressures... (what exactly are u talking about??)
oil pressue will fluctuate when u apply the throttle accordingly (there is a thread with the
correct oil pressures when idle, and throttle, etc - try a search)
Fuel economy varies as alot of force induced cars have either been boosted or have some form of extensive modification - I am not sure about the stock standard economy you
will have to try a search, or post in the forced induction section.
As for an RB25DE (non turbo) I have managed a bit over 1/4 tank for about 200km
that is about 20~25L driving pretty hard.
theres a big difference in price between a rb25de and a rb25det. If u wanna keep it non turbo then i recomend a rb25de. makes alot more torque. A decent mechanic should be able to do the labour costs for 500-600 i rekon, as this is wat i was quoted to do a rb25NEO in my r33. Bear is mind that other bits might need changin as well so these are additional costs.
Is the RB25DE and the RB25DE NEO-Spec a straight swap conversion? I am aware that
the Neo has a few extras such as stronger internals? and bits here and there...
but things such as wiring? ecu? compression? could you just swap the engine and retain
the old stuff.
Think the RB20E will be able to take a shot of N2O just for fun? or will the internals be a bit weak on this engine?
The oil pressure gauge shows a lower than usual reading every so often at idle and in motion. I know it should change on applying the throttle but the reading doesn't seem to show this.
There doesn't seem to be any performance problems, just the leaking engine.
Whatever, I'll leave that to the mechanic.
    • New tyres bleed the brakes sort out lights and historic registration time for the sub r31 IMG_0551.mov
    • Had a chat to Tony Mamo - he advised that looking at the graph's shape (regardless of number translation) it shouldn't be levelling off like that up top. He said it looks like the car is running a restrictor plate or something of that nature. Luckily the last dyno pull on E85 was saved to the PC - So I did a quick trace of Barometric KPA vs Intake manifold pressure, and lo and behold I see a copy of the 'waves' I was seeing on the dyno: I'm not entirely sure how to go about addressing this. It may be worth sacrificing IAT to run a more direct intake for the motor. Though packaging this could be flat out impossible given the constraints of the car. I should have removed the intake pipe to see if this made a difference but looking at this graph I now have something to potentially test in the future and think about. This one is from an old track day log in the OLD setup going through gears on track.
    • Oh, I forgot too, all the multimedia stuff captured and sold through things like people playing Pokemon Go. Pokemon Go specifically, can actually be traced all the way back to a CIA investment company too. So yep, they're watching everything. Not to mention the new stuff where they've worked out how to use WiFi signals to be able to map occupants inside of a building. That one would be something that I see being more used in public/government buildings, as you need to understand the signals when the room has no one in it first. It's not as easy as Hollywood would like you to think it is.
    • Followed ☺️ Assuming those are NEO rods, then at least 400kW all day.
    • Lets keep this going , Spotted this very stock V35 in Penrith and also saw a nice R32 FLY past me on Castlereagh rd , sounded really good.
