I have got a R33 GTS with RB20E engine in it. I think the head gasket is leaking as there is oil leaking around the top cover!!!
Anyways..I thought rather than doing any work fixing this engine..I wanted to change it for the RB20DE (get a bit more power with a little loss in fuel economy? (its my daily run around so can't afford the petrol bill of a turbo)
Does anyone know if this engine can be changed in to the my R33 chassis? Will it be a straight swap or do I need to change other things like the gearbox and clutch?
Thanks
Going on holiday for a week soon so thought I'd send my car to the garage while I'm away! :(
https://www.sau.com.au/forums/topic/64183-changing-from-rb20e-to-rb20de/
Might be right about the rocker cover...I'm might be giving parts the wrong name! cheers. My oil pressure fluctuates while driving at steady speeds, could this be due to the loose rocker cover?
And yeah had a chat with my local mechanic...said the wiring probably needs changing and other bits and bobs which would add up to a big labour bill....might aswell get a proper engine put in!
So I think I will try the sealant for now!
Was hoping that it was just a case of unbolting the rb20e and dropping in the rb20de...nevermind. Just happened to come across a crashed RB20de.
Whats the fuel eco of RB25DET? I do 60miles (100km) everyday so i presume my fuel bill will be massive!
Thanks for sharing :thumbsup:
Rocker cover dusnt have any affect on oil pressures... (what exactly are u talking about??)
oil pressue will fluctuate when u apply the throttle accordingly (there is a thread with the
correct oil pressures when idle, and throttle, etc - try a search)
Fuel economy varies as alot of force induced cars have either been boosted or have some form of extensive modification - I am not sure about the stock standard economy you
will have to try a search, or post in the forced induction section.
As for an RB25DE (non turbo) I have managed a bit over 1/4 tank for about 200km
that is about 20~25L driving pretty hard.
theres a big difference in price between a rb25de and a rb25det. If u wanna keep it non turbo then i recomend a rb25de. makes alot more torque. A decent mechanic should be able to do the labour costs for 500-600 i rekon, as this is wat i was quoted to do a rb25NEO in my r33. Bear is mind that other bits might need changin as well so these are additional costs.
Is the RB25DE and the RB25DE NEO-Spec a straight swap conversion? I am aware that
the Neo has a few extras such as stronger internals? and bits here and there...
but things such as wiring? ecu? compression? could you just swap the engine and retain
the old stuff.
Think the RB20E will be able to take a shot of N2O just for fun? or will the internals be a bit weak on this engine?
The oil pressure gauge shows a lower than usual reading every so often at idle and in motion. I know it should change on applying the throttle but the reading doesn't seem to show this.
There doesn't seem to be any performance problems, just the leaking engine.
Whatever, I'll leave that to the mechanic.
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
    • There's always "MIG it up and grind it back".
