hi pplz, just wondering about a few things, i bought a timing belt off ebay,to fit an RB25DET engine, now i was talking to a guy 2day and he was telling me that his coil packs were stuuffed and that he needed to get RB25DET VVT (VAIRIABLE VALVE TIMING) coil packs off the series 2 for his car. that got me thinking that if my car has a vvt engine in it, does that affect the type of timing belt you buy for the 2 motors (VVT & Non VVT) and how do you check for VVT on your motor?? ive heard if your timing cover has a round plastic lump on the fron tof it, it is VVT??? can any1 confirm this. thanx for all your help. 85URK
https://www.sau.com.au/forums/topic/64188-qs-about-vvt-rb25det-what-is-what/
  • Replies 42
The coil packs (which initiate the spark) have no relationship to VVT (which controls when air/fuel or exhaust gasses enter/leave the combustion chamber). The need to get S2 packs is probably because the S2 packs have an in-built igniter, whereas the S1 packs require a separate igniter module.
VVT changes the relationship of the camshaft to the cam pulley, so the same belt should operate the cam pulleys, irrespective of the presence or not of VVT. As well as the "power bulge" in the cam cover, VVT can also be identified by a small solenoid mounted at the front of the head, immediately forward of the inlet manifold, near the 2 temp sensors.
The RB25Det with variable timing is also known as the 'NEO' RB25det. It originally came out in the R34 GTT and it has a few more kw's compared to the R33 version. The Neo was also available with a tipronic auto as well as a 6 speed manual. The Neo did not come out in the R33 so if you find one then it's been converted with a R34 unit. The actual physical
differences in the two motors is inside the head as there are slight differences in the water/oil gallaries where the head meets the block.
Some people doing the RB25det head on a RB30 block conversion will know about this as it's the normal non-Neo head that is used, the Neo RB25 head does not work with the RB30 block as some of the above mentioned holes does not line up.
incorrect, the new engine was only in the r34, but variable valve timing was on the r33 rb25det as well and that engine is NOT reffered to as the new engine. its only on the inlet side on an rb25det in r33s.
in relation to your question, the coil packs are different on series one and two skylines but the difference is not related to vvt or no vvt so dont worry.
The R33 VCT is either on/off for the advance like MonstaS4 said.
On the R34 Neo it is variable the amount of advance applied to the cam, not just on/off the full 20deg advance.
Atleast thats my understanding.
It doesn't do anything with the valves like a Honda VTEC does, it just advances/retards the inlet camshaft, much like an adjustable cam gear would do, except it isnt fixed. If that makes sense.
Firstly, its called VVL on Nissans. VVT is on Toyotas
VVL was introduced in the R33 Series 2, I think. May be on the Series 1 too....??
Its a wonderful thing to have, I feel it after 5000 rpm. It gives huge kick to the point it feels like a second small turbo kicking in. Its by no means slow before 5000 rpm either
Here is a pic of my engine bay, the 'lump' is just to the left of the sticker on the cam cover
mine is a gts-t type m 95 model and according to that pic with the lump on the left of the cam cover, then mine has this too???...so confusing what came with what lol... there was a thread that i couldnt find again that stated some gts-t type m came with the series 2 engine, how can i tell the difference by lookin at it?
ben...
Hi guys, all R33's I have seen have VVT, both GTS and GTST, 2 door and 4 door. Even Stageas have VVT. It varies the inlet valve timing only, does nothing to the lift or the exhaust timing or lift. The only RB25DE I have seen without VVT was in the later R32's. The R33 RB25DET has simple "on" or "off" VVT, it is "off" up to around 4,500 rpm then "on" from there to rev limit. The "off" mostly is for emmisions and fuel economy, although it does help slightly with torque. The "onj" is for power, although it doesn help slightly with emmisions and fuel economy..
The R34 RB25DET (Neo, as it is sometimes called) has infiniitely variable VVT, the (later generation/smarter) ECU moves the inlet camshaft timing around depending on the load conditions (not just RPM). The Neo versions of the RB25DET are good for 206 kw, around 20 more than the R33 versions. They also have solid camshaft followers (R32 and R33 RB25's have hydraulic).
My 20 cents worth:cheers:
Sydneykid, i'm not calling you a liar, but i'm pretty sure the R33 NVCS is OFF from 0 - 1050rpm, then ON until 4500rpm, then OFF again until redline. This is how it is setup on my RB30DET and I've noticed a distinct lack in power up to 4500rpm when the NVCS plug falls off the solenoid! (due to lost metal retaining clip).
Another way to spot variable valve timing without removing anything.
The solenoid sticks out of the head below the fuel pres. reg.
You can identify a s2 motor by its build date.
The underside of the coil cover (this is 10/94 =s1)
The front of the head, with the timing gear removed (again 10/94 = s1)
Hope this helps :rofl:
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
