READ THIS WHOLE POST BEFORE POSTING ANY QUESTIONS OR SENDING ANY PM's
FAQ: Apexi PowerFC - Frequently Asked Questions
Intended Audience: Anyone considering an aftermarket ECU
Technical Level: High
Duration: 1 hour
Effort: High
Result: Excellent
!!!Caution/Achtung/Attenzione!!!
Follow this guide at your own risk. You have been warned. We are not responsible for any actions you take. The information contained herein is a guide and should *not* be acted upon with consultation from your local tuner (he/she may not agree with my comments / suggestions). If you are unsure or are not confident don't do it.
This guide is a document in progress among the Skylines Australia car club and is a User orinentated FAQ for the Apexi PowerFC stand alone ECU. This guide should be used if you have questions regarding the Apexi PowerFC and it's functions
This thread is NOT the PowerFC FAQ but a tracking document for changes and other questions - This is NOT THE FAQ ITSELF
Before posting in this thread please do the following;
1. View the PowerFC FAQ here: a the bottom
2. If what you are looking for isnt covered in the FAQ, search inside the FAQ using your web browser search or find command
3. If what you are looking for isnt covered in the FAQ, search again inside the FAQ using your web browser search or find command
4. If what you are looking for isnt covered in the FAQ, search again and again inside the FAQ using alternate keywords and names using your web browser search or find command
5. Try a google search on what you are looking for
6. Review the posts in this thread to see if its not covered already
7. You may post in here if you think the question hasn't been answered already but we aren't obligated to answer
powerfc-faq.pdf
Nice tech thread...
Love it... Good info and good suggestions for mods....
Good to see some info on the PFC in one thread...
Now we need someone to do the same for th Wolf 3D... (I have PFC, just like to see anohter point of view for the youngins... non PFC'ers i mean)
  • 3 months later...
  • 3 weeks later...
I want to set my thermal fan/air-con fan to activate a bit earlier than what has been set on my PFC i belive so i will need the data logic right?
By the way my car is an R32GTR,
I've seen water temp on my hand controller read up to 100+( back when i had issue with my radiator was a bit block ) and the bloody fan wouldn't kicks in unless i have the aircon on which explain in a way BUT in my 33gtst wherther i had aircon on or not, the fan still come in.
Another word the 33 air condensor fan WORKS as a back up sourse as well but not in the R32?
This is an issue where i havn't found an answer by anybody wherther it was ICE or Racepace, anyone can clarify this would be GREAT.
hey guys just wondering...i just got my r32 gts-t power fc...just wondering what u guys think of the power fc boost controller kit...are they really accurate and reliable...i heard that the avc-r's sometimes boost spike...this is one thing that i deffinately dont want...will the power boost contrller kit do this
everyone that says the powerfc boost controller kit is crap doesn't actually have any proof and just blames that cos they dont know what the problem is. its the same as the avcr solenoid. i dont see why there would be any issues with it? its a valve, it watches some events and open/closes accordingly. there are plently of guys using powerfc boost kit. perhaps you could pm one of them and ask
Technical Level: Medium
Duration: 30 minutes
Effort: Medium
Result: Excellent
Follow this guide at your own risk. You have been warned. We are not responsible for any actions you take. The information contained herein is a guide and should be acted upon with consultation from your local tuner. If you are unsure or are not confident don't do it.
URL: http://members.dodo.com.au/paul/docs/power...powerfc-faq.htm
Hi, I intend on buying a PFC for my 33. One thing I would love to know. What is your mileage per tank after you tuned the PFC? Also with what mods and at what boost pressure do you run.
updated again. fixed some spelling mistakes. removed the retarded formatting and made all the paragraphs into tables so they resize correctly on all browsers/screens. added wierd idle problem. added some more info about fc tune (upcoming product)
  • 1 month later...
updated again. added the following
-> regarding maxing out load points
-> sensor check page
-> powerfc menu options
-> powerfc software
-> self tuning with map tracer
-> light load trace and fuel economy
  • 1 month later...
Hey paul... quick question... the pfc map trace and ignightion map trace on your web site (in excel format in the dyno graphs area).... What mods were on your car when these were produced... Casue my are heaps different...???
i found some top end flat spots and it was traced back to my exhaust shop not fitting a split front/dump pipe and leaving the stocker one on. i thought did the split front/dump but turned out they didnt so that kinda killed the top end power. since getting that fitted it ran awesome and didnt loose top end, ak run out of puff
Yeah i already have a split dump and full 3" with high flow....
I need to change the setting cause im using way too much fuel atm....
Try 24litres per 100km's.... I have a nice burn mark on my rear bar and i had a small exhaust fire the other day so its very important....
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m. Or is the easiest solution to reshim the Nismo diff to make it looser?
