updated again:
fixed missing image
fixed spelling mistakes
fixed grammar mistakes
added hyperlinks for each section
added section split based on content
added self tuning - fuel economy
added info on changing airflow meter
added info on powerfc tune protect
expanded info on tuning options and expected results
do they release slightly differant maps in the diff versions of the pfc/hand controller maybe ?
I was comparing my ign map to the one in the faq, and in some points (outside of the first 10x10 range) they were off by like 10 degrees. I also compared them to the ign map in the FC PRO software, they was differant as well.. ??
Mine is pfc v 5.11, and hand controller v5.01A (might be the other way around)
Wered you grab the stock map on the faq from ?
as far as i know the stock maps don't change very often
i havent at least heard they do. they were taken from my tune
but i may have done it before i did factory reset so they could be a "tuned" ign map. when i get datalogit, ill copy mt tune. reset to factory defaults then upload the defualt maps to my site and then restore my tune and upload that as well. ill expand the powerfc faq a lot when i have a working datalogit
added boost control pics, info and wiring
added djetro harness and wiring and manal
added datalogit specific extra features
added datalogit logging options
added datalogit additional functions
corrected spelling mistake of my name
corrected double up paragraph
updated again:
added airtemp sensor on unsupported car info
added powerfc inside cover photos
added reflashable powerfc info
added custom hack / diy / hand controller holder pics
added basic hand controller use
added checking sensors
added checking functions
updated install info
those 2 manuals are old as the hills and are for rx7. They are also the older powerfc so its not upto as the japanese SR20/RB25/RB26 manual.
it comes off the main wiring haress which i think is a digital output from the gearbox somehow, ill find out
It most certainlly a gearbox feed... The only other alternative is the ABS sensors but it still works on non-ABS skylines so it must be a gear box feed....
Plus the skyline has a digital sendor to the dash display....
hey guys i have a question for those in the know
because the nvct cam timing is constantly variable on the NEO rb25, can the PowerFC be mapped for this function, or how does that work?
with the r33 rb25 its either full advance or full retard no inbetween. and is activated by a simple on/off switch in the ecu at the desired rpm.
anyone know how the powerfc and rb25neo nvct perform?
is it completley mapable throughout the entire rpm band or whats the go?
no idea but if you find out let us know, will add to powerfc-faq
the vvt on the rb25 (33) isnt controlable and its automatically controller by the powerfc emulating stock ecu functionality. you can see it turn on and off under check sensor / sw but its not controllable or editable in map form
    • Hi all,   anyone know where I can pick one of these up for a reasonable price? I just resprayed my rear trunk due to fuel stain and my new muse spat install.    added a photo for some content 馃ぃ馃憤   thanks
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 馃槂
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
