Hey Paul,
I just read there is a VCT and non-VCT PFC models for the RB25DET. Is this true? If so, how can I tell which mine is (second hand, no box). I don't know the model code right now cos it's at home.
all rb25det models support VCT
Is there a specific Power FC for a R34 GT with an RB20DE normally aspirated engine?
No the ER34 PowerFC assumes you have Rb25DET Neo and associated Neo ancillaries
Will the Power FC for a R34 GT-T work?
No I wouldn't expect so as it will expect Neo 25t, with Neo injectors, coils etc
You would need to look at either using an RB20 Ap Engineeering PowerFC or do an engine swap
Using an Rb20 AP eng is probably just as hard as the rb20de you have probably still has the R34 traction control etc fitted
so its not just a normal rb20de but a half cast between the RB20 and Neo engine setups
hey Paul..just got a question for ya...my car doesn't idle well...it just keeps hunting even when i have selected the R33 AFM and did the learn idle for 30 mins i've actually done this twice....so yeah i donno where my problem is would you be able to shed some light?
Cheers
Chi
bought a PFC for a R33 GTR and plugged it into my R32GTR and it wont start just sits at the apexi logo screen. Now i know this is supposed to happen with incompatible hand controllers but this came from a working skyline? any ideas? need help urgently as the car is sitting at the tuners waiting! THanks heaps
is the PFC combo new or 2nd hand?
if its freezing on the apexi logo the hand controller is the wrong version or its damaged etc
the car probably isnt starting as it needs to be DATA INIT'd and reset to factory defaults like it might have diff injectrs / afms etc
from what i understand the R33/R32 gtr pfc is the same?
but from nenguns compatibility table there is an older version hand controller 415-N001 which on works with R33 GTR? The newer model 415-X001 works with both R33GTR and R32GTR, could this be the issue? i thought since the number is FCC3 it was a version 3 hand controller meaning it would be a newer model?
yeah so you have the older style GTR PFC and the newer style hand controller which is why its freezing at the apexi logo
you need FCC NT hand controller or N001 from nengun's site
32 / 33 GTR PFC is the same, but you need a matching hand controller
if you have PFC RB26 then you need FCC NT or N001
If you have PFC GTR33L then you need FCC 3
so this would have worked in a 33GTR but obviously not in my R32GTR? thanks for the help buddy! ie. could this combination every worked together or was i sold a bullshit combination that never worked?
Edited by c0ris
Hi Paul
Just a quick question, if i want to swap a RB26 engine (either a 32 or 33GTR) to my current R34 GTT which already has a PFC. Do i need another PFC based on the GTR model or can i still use the GTT? Would my a/c or other electrical works with a GTR PFC?
Driftmeister, I have a 98 GTT with a PFC for the original engine (RB26DETT(Neo). I did a swap with a BCNR33 RB26DETT but I kept my same PFC and the original wiring harness for the GTT. My GTT runs ok but with many symptoms here and there. My power steering doesn't work (nothing to do with PFC), no a/c (also nothing to do with PFC). Those two things are just compatibility issues. I just need to buy a new pwr steering pulley and an OEM compressed a/c line for a R33 chassis.
Electrical Problems...
My check engine light stays on but there's no problem...
No TCS..
Oil Temp Guage doesn't work.. compatibility issue... aftermarket sensor will fix that.
Theres a compatibility issue with the injectors. The PFC for a GTT runs on a high impedance system, the RB26 motor for a BCNR33 uses a low impedance system. I lucked out, I ordered some Bosch 444cc Green Top High Impedance injectors from the US (cheap but they sell in set of 8.. I just sold the other 2 to my shop), my tuner has a friend who's a Robotics Professor and he built a converter sensor to change the RB26 system to high impedance.
There were trial and error things that I went thru with my air sensor since I only have that one from the RB25 motor. My tuner had to modify the pfc to read the different air flows. We were trying to go D-Jetro but we still need to work things out to see whats best.
I suggest buying the correct harness and cpu for the RB26 motor if you have the loot to do so... you'll eliminate many headaches.
I'm about to get my Tomei 276 l/hr high flow fuel pump installed this weekend. Were expecting ~400whp, 62whp gain from what it is now. All I have is
Apexi Filters (both are for the GTT haha saving money again)
full custom exhaust
FMIC
SARD Fuel Regulator
Exedy Hyper Multi Plate Twin Clutch
Blitz SBC-iD III
HKS Turbo actuators
and the Tomei fuel pump.
Hope my mistakes shed some light for you!
No TCS..
full custom exhaust
FMIC
SARD Fuel Regulator
Blitz SBC-iD III
HKS Turbo actuators
Thanks for your prompt feedback bro..appreciate it. I didn't expect to have quite a number of compatibility issue. I thought if i were to go RB26, the best would be to use the complete harness from the 33GTR and get a PFC for the it. I would presume the TCS & A/c wouldn't be working and a/c require a separate switch for it.
Anyway, now i think it's better to just mod the GTT 25 engine which is less headache. Cheers!
  • 3 weeks later...
my r33's exhaust light is on all the time, i couldnt find an answer in ur power fc guide, if its a sensor problem, what should i do if it is? and my check engine light is on a fair bit too, but my knock is under 20. My warning functions r all on too.
