Hi paul, sorry to bother you so many times with PM's and email. At the moment i'm kinda desperate for a solution and worried about the fact my car won't be fixed.
Prior to all these problem, i've placed my battery wrong way around and i suspected i've fried the powerfc. i took my power fc down to a place here who specialised in them. they looked over it and couldn't find anything that was wrong. thank god, s o the powerfc wasn't fried (i thought). i went and got my car retuned, however the car won't idle. report i got from the tuner was that the power fc idle solenoid driver needs repair. so i taken my power fc back and they looked over it again and said there's nothing to be found. plugged it back in and the car still not idling. now prior to all the mods, i know that my car was idling with the stock ECU. So that cancel out the possibility of anything on the car side (tps, idling). the mechanic said there's power going to the TPS, but there's no signal coming from the power fc. And this is wear i'm stuck and dumbfounded. the power fc has been fixed twice. i couldn't exactly go out and buy another power fc, as mine has been discontinued and i couldn't justify spending another 1k and being back to square one. a mate suggested that if i found a 2nd hand/ faulty power fc i could salvage the part (idling solenoid driver part) needed to fix my car. at the moment i can only find a 2nd R33 GTR power fc. Could i do this? and fix my power fc which is for a 94 s14?
any input and advice would greatly be apprieciated.
tn-
hi paul
1st of all would like to thank you for taking the time to help every one out with a top FAQ page for the power fc!!
i do have a question that has not yet been asked:
i have a air/fuel ratio gauge with wideband lambda (VEMS)
this replaces the stock narrow band lamnda but the gauge offers a narrow band output for the stock ecu.
it also offers wideband output for aftermarket ecu`s
1v wideband
2v wideband
3v wideband
my question is:
can i run the power fc on a wideband lambda on the 1v wideband output setting?
what would be the pro`s & con`s of this?
thank you
jake
ps: power fc model: ecr33 for the rb25det
hi paul
1v wideband
2v wideband
3v wideband
my question is:
thank you
jake
the PFC and std 02 sensor from memory is from 0.0v to 1.0v from a narrow band 02 sensor
so that being said, if your wideband sensor has an optional output for narrow band applications and its in the range of 0 to 1.0v then it should be fine
the PFC wont be any wiser, as long as the scale and logarthmic of the output is fairly normal it should be ok
well the pro is obvious, you can ditch the narrow band sensor and have 1 wide band sensor for both uses (wide guage and narrow ecu)
con im not sure there is any? as long as the output is normal and 0 to 1.0v it should be fine
the worst case would be the 1v output is useless and it will waste fuel on cruise
you can check the input signal on the PFC by viewing ETC, SENSOR SW CHECK
and checking out what 02-1 is at idle - it should be under 1 v
Hey 2 save me looking through all the pages i have a question with my pfc. my car has one of the apexi turbo timers that have the a/f ratio in it and when watching it while driving the ratio varies between 10.0 and 14.5 which im geting fixed up shortly but the thing that im confused about is when i lift off the throtle the air fuel ratio maxes out at 20.0 but it might even be more as thats wat the timer maxes at. and while i was on the way back home from superlap i was sittng at the lights at lithgow and had a look and at idle it was at 18.5 but as soon as i put a litle bit of throtle on it would drop down 2 14.5. is there sumthing wrong sumwhere that i should look at. i have datalogit and can try get a copy of them 2 pm sum1 if they want 2 look at them 2 help me as they r on my dads laptop. thanks in advance
hey guys ive just bought a power fc for my rb20 r32.
it came with no hand controller so i am trying to figure out which model it is as ive heard that i need a specific one.
i took the case off of the ecu and the nec chip in the middle for some reason has a white sticker saying r32 sr20det??
i msg'd back the bloke i bought it off and he said that he had just pulled it out of his mates rb20 ceffy. so i believe him.
so anyway. wondering if anyone can help me out
the numbers on the nec chip are as follows:
D78P334LQ(A)
0303RK007
inside there is another green chip approximately 8cms long that has the apex'i logo then CEX-9609-030-RB25
on the outer casing of the unit it has another sticker with PFC R32 A0236 and the AP. ENGINEERING under it
is this safe to assume this is a modified rb25 unit by ap engineering?
which hand controller do i need to get?
thanks heaps for any help people.
cheers ross
ps. will it be any concern that i am actually running a c33 laurel rb20??
pps. will my bee-r rev limiter still work??
Edited by jeffers1987
you can send a pm to "abu" he has an ap eng r32 PFC for sale with hand controller
the hand controller will have a sticker on the back with a version no, it should be FCC NT or FCC1
the model when purchased new is usually listed as N001
which is FCCNT or FCC1
the newer style hand controller is usually listed as X001
which is usually FCC3
FCC3 or X001 part # will NOT work - dont bother
check with abu but im certain it will be FCC1 or FCC NT- in the case find an FCC NT or FCC1 or N001 part # hand controller (nengun.com have it new)
the 02 sensor value displayed on the Apexi turbo timer is pointless and a waste of space
it will provide you with nothing useful and will never show anything accurate, its a slow and narrow sensor.
simply ignore the readout and dont rely on it for anything
G'day,
Sorry if this thread is wrong for my question, I'll ask anyway.
I have '98 ECR33 with 34 CAS (one of these 40th anniversary editions), I'm interested in one that has been previously in Series 1 R33.
My question is, would the PFC from Series 1 work on Series 2 with 34 CAS?
I'd like to know this before I go buy it.
Thanks in advance.
Cheers
Grant
thanks thats wat i thought its going in 4 a tune shortly anyway and will have a wideband installed 2 it.
G'day,
Thanks in advance.
Cheers
Grant
it will work fine, the CAS is visually different but works the same
you wont have any issues, i know of a 40th anniversary R33 1998 model with normal R33 PFC works fine
can an R34 GTR with a power FC retain its stock AFM instead of upgrading to the Z32s ?
Also what are the drawbacks of running with the stock AFM ? Cheers fellas.
yes the standard powerFC version uses standard AFMS
only the djetro version removes them and uses its own map sensors
there are no drawbacks of using the standard AFMS
using AFMS is better than using map sensors
the standard AFMS will max around 300rwkw ish
and youll need to upgrade them - the nismo AFMS
are z32 internal inside GTR shells so you can retain std pipework, ducting etc
Z32s are 80mm so if you goto z32s you have to change all the pipework etc
nismo AFMS are 65mm but with z32 sensors inside so same power level
just plug and play on the GTR with std airbox, pipe work etc
hi Paul,
i plugged a PFC into my car last night and has some funny symptoms with my ATTESSA
CAR
R33 GTS4 RB25DET S1
PFC was from a S1 gtst my thoughts we it shouldnt matter that the car it came from doesnt have AWD as the main ECU doesnt handle that stuff but i had my AWD binding up on me on a few occasions
the only other thing that has been done different is i put my front shaft back in after it being out for about 6 months so could it be a coincident that the same night i put the shaft and pfc in i get weird binding
also i did drive it 45mins from my tuner to my house with no binding on standard ecu
hi Paul,
CAR
R33 GTS4 RB25DET S1
hi
when you say issues - what issues? what errors / warning lights?
it doesnt matter what series the 33 PFC came from 1 or 2 its the same unit
i suspect the 4wd light is always on when you run with the PFC
if thats the case, find the TPS wire on your loom
i had this issue with my R33 GTST with active LSD
what happened was the stock ECU relays the TPS signal from the original source
onto another wire which runs to the active LSD computer in the boot
the GTR 4wd system is the same so stock ECU would relay the original TPS signal
onto another wire that runs to the boot, but the PFC doesnt do this
as apexi didnt cater for wierd spec R33s like yours and mine (that is GTS4 and GTST Active lSD versions)
both need the TPS signal relayed to the boot computer
so find the TPS signal on your loom and then check where it goes
it needs to run to your 4wD computer in the boot (there will be a TPS wire there)
oh it only happens at low speed seems to be when pulling out my driveway or into car parks
TPS = throttle position sensor?
might leave that one for my tuner
oh and when the issue happened today i looked @ my AWD light and it didnt come on but what it seems to do is put the attessa into 100% mode
oh and my AWD light isnt continuously on
Hi just a bit confused here
the knock sensor reading on my pfc always reads , well its sort of a straight line like an 'l' any ideas ??
tried doing a search but an error came up
its a Bar graph style view
as you get more knocking the line will move like this
to
and
make sense?
if you press up in the thtat view you will get a digital readout of the same value
anything over 60 will make the engine check light flash
    • Heres another fitment photo. redrilled the pattern to 5x112, and threw my audi´s rims on. had to touch the upper control arms with grinder, because the "sharp corner" was sticking about 2-3mm on the tire path. i have the "fender lip" mostly cut off, otherwise these (too) would contact with it. 20x9.5 ET25 rear    265/30 20x8.5 ET20 front    255/30 they are temporary, and look too big for the chassis. searching for 19s to it.
    • From experience, it will come back to bite you haha.
    • Background: my BMW 225i hatchback (rebodied MINI/X1) came with 3x RE003 and 1x Goodyear Asymmetric something. The RE003 roared and slid around, the Goodyear side was quiet and grippy. Definitely my car was thrashed before it got sent to dealers. My brother also got RE003 all round on his old VA WRX STI, I wasn't impressed with them, car was loud so can't comment on noise. Anyway, Hankook stopped making/updating V12 Evo2. So bought S1 Evo3 runflats. Great daily duties tyre and not that harsh ride. Tyre reviews site/youtube rated them as best stopping in the rain and I believe them. Next set, Goodyear Asymmetric 5 non-RFT. It beat PS4 in tests and is like $100 cheaper, so put them on. Great tyre, more grip then S1 Evo3 but a tad noisier as expected, still rocking them. Next set I am looking to go runflats, probably the new Hankook Evo. Although the new Pirelli PZ5 did well in tyrereviews test. Or go Goodyear Asymmetric 6 which was top tyre last year. The V12 Evo2 on my gen5 Liberty GT wagon did great in cold condition (drove to snowy mountains for a day so my husky can feel his ancestor's roots). Super impressive performance for $120 each lol. Never skimp on tyres, brakes, suspension. There's old pics of my R31's crappy random brake pads bending in the caliper at Oran Park track day somewhere around here. Anyway, my 2 cents.
    • I said "Matlab clone". I could throw one onto one of my linux VMs. Probably only take 10 or 20 hours to sort out the dependencies, relearn how to use it, etc etc.
