yeah what he said^^ fc tune doesnt seem to be available, and i read copilot isnt very good..But it would do, as im not doing any tuning really just need it for basic map switching..
I have searched and found numerous DLs ..but nothing that wants to work..I thought there was one on your site but if there is i cant find it..
I been searching for 4 days man..
i downloaded co pilot but dont have datalogit cable so can only load the software and look @ it
do you have the datalogit software and cable
Was going to get the HAKO cable, which i beleive would work with copilot...
EDIT there was another DL here from 2003 that i attempted but cant open HD1 file yet ..not even sure if its right..
Edited by Arthur T3
Have a power Fc now and wanted to test to see if it works.
Plugged in and initialized.
All seems good except "Engine Check Light" was on throughout the power on.
Is this a problem undiscovered by my Remapped access auto (blitz) ecu or a problem with the power fc?
Thanks
if all your doing if putting ignition on but not starting i think that's correct you should get all dash lights warning and not
Sorry, my mistake.
I meant, ignition on, reset the power fc, then turned ignition off, then back on all the way to start the car.
Then the engine warning light remained on and the others turned off.
Thanks
the engine check light (orange engine icon) comes on when a stock sensor is out of range, disconnected, fault or broken
view the sensor that is causing the issue by looking at ETC, SENSOR SW CHECK and look for a sensor with a black highlighted name
of course if you had have read the PFC FAQ on page 1 you would have known that already
on cars such as R32 and RX7 they do not have an engine check light (orange icon) and use the exhaust overtemp light instead (red CAT icon)
so if you have HR32 then its the same deal, the light is used to advise you of a stock sensor out of range, not working or mangled
  • 4 weeks later...
In electronics, fall time (pulse decay time) \scriptstyle t_f\, is the time required for the amplitude of a pulse to decrease (fall) from a specified value (usually 90 percent of the peak value exclusive of overshoot or undershoot) to another specified value (usually 10 percent of the minimum value exclusive of overshoot or undershoot). Limits on undershoot and oscillation (aka, ringing or hunting) may need to be specified when specifying fall time limits.
Paul,
Have you ever had any problems with the hand controller giving false readings or causing the car to knock
Mine got looked at today and on datalogit its fine on the map watch, Knock was fine
But on hand controller I get high readings at the same load points
Have you heard/experienced anything like this before?
Thanks
covered in the PFC FAQ
the datalogit and hand controller should not be used at the same time. this is because they share the same bus and bandwidth from the powerfc
that is, each data cycle may be missed by one and the other. so cycle 1 knock of 40 daalogit see's it, but hand controller doesnt, cycle 2 hand controller see's it and datalogti doesnt
its fine to use both to just play around etc
but if you are logging and tuning you should only use at at a time, and not both as it's a shared bus and was never designed for dual devices reading data at the same time
Thanks Paul
It seems to go a bit deeper then that though, when logging individually with both items I'm still getting more Knock on the hand controller then in datalogic. It got looked at yesterday and my tuner said it looks good, plenty of fuel and the timing is not as far as it could be. Datalogit is showing everything is fine, just when the handcontroller is in I get knock at random times. Ive got nothing plugged in at the moment and havent seen my engine light flash to indicate high knock levels since.
I'm thinking the hand controller might just be a bit funny. The main points it seems to be knocking are low revs high load (eg Foot flat to the floor in 5th gear going between 60kmh-80kmh etc)
Sorry I was a bit vague in my last post
Just let me know if you've experienced this before. Im going to do a bit more logging individually with hand controller only and datalogit only when I get the time
Thanks
is your tuner logging basic or advanced knock? should be similar but can be slightly different. how many different things is he logging at once?
also, how high are the readings your getting on the h/c?
    • I'm thinking that this is such a small part of the problem that you could easily forego the vac pump and just achieve 90% of what you need, which is keeping the gate open when off boost. It's not as if there are not already techniques to keep a gate fully closed under boost. After all, you have boost. Just use a wastegate actuator that will allow you to apply the boost on the appropriate side, just like every external gate out there.
    • Heres another fitment photo. redrilled the pattern to 5x112, and threw my audi´s rims on. had to touch the upper control arms with grinder, because the "sharp corner" was sticking about 2-3mm on the tire path. i have the "fender lip" mostly cut off, otherwise these (too) would contact with it. 20x9.5 ET25 rear    265/30 20x8.5 ET20 front    255/30 they are temporary, and look too big for the chassis. searching for 19s to it.
    • From experience, it will come back to bite you haha.
    • Background: my BMW 225i hatchback (rebodied MINI/X1) came with 3x RE003 and 1x Goodyear Asymmetric something. The RE003 roared and slid around, the Goodyear side was quiet and grippy. Definitely my car was thrashed before it got sent to dealers. My brother also got RE003 all round on his old VA WRX STI, I wasn't impressed with them, car was loud so can't comment on noise. Anyway, Hankook stopped making/updating V12 Evo2. So bought S1 Evo3 runflats. Great daily duties tyre and not that harsh ride. Tyre reviews site/youtube rated them as best stopping in the rain and I believe them. Next set, Goodyear Asymmetric 5 non-RFT. It beat PS4 in tests and is like $100 cheaper, so put them on. Great tyre, more grip then S1 Evo3 but a tad noisier as expected, still rocking them. Next set I am looking to go runflats, probably the new Hankook Evo. Although the new Pirelli PZ5 did well in tyrereviews test. Or go Goodyear Asymmetric 6 which was top tyre last year. The V12 Evo2 on my gen5 Liberty GT wagon did great in cold condition (drove to snowy mountains for a day so my husky can feel his ancestor's roots). Super impressive performance for $120 each lol. Never skimp on tyres, brakes, suspension. There's old pics of my R31's crappy random brake pads bending in the caliper at Oran Park track day somewhere around here. Anyway, my 2 cents.
