Faq: Apexi Powerfc - Frequently Asked Questions
paulr33
well the H/C gives strange readings, sometimes I'll be at say 1/2 throttle doing 100kmh accelerating to overtake someone and it will knock its head off, Ive had readings up around 160, but more commonly get between 60 and 90. But theres no audible knock from the car ever, It runs smooth and perfect.
Pretty sure we were logging advanced Knock on the datalogit and it was hitting 30 at the most when we were doing that. And that was doing some high load runs in 4th, a full run through 2nd gear and some playing around in 5th where id noticed some knock levels. Nothing to be worried about in datalogit but the HC quite often logs worrying numbers.
He seems to think the tune is fine and the HC might be funky, so I've decided to take it out for now, thinking about borrowing another HC and seeing if it makes a difference.
Hope that info will give you a basic idea of whats going on :D
EDIT: Sorry there was 2 cells that were registering around 44 Knock (advanced Knock) on datalogit which were touched up, now register below 30, but they were the largest readings that I can remember
Edited by 89CAL
johnoo is bang on
but also
when you are viewing hand controller knock is it on the street or dyno
and likewise with datalogit, is on the street or dyno
i found everytime cars knock differently on street with the owner driving them vs the dyno and dyno operator
i think this is because the owner drives it differently to the dyno simulator and also the owner usually changes gears differently slightly etc
so are they both in the same identical conditions??
Yeah same conditions. I've observed the HC readings since it got tuned an know roughly the points it knocks. So we plugged the datalogit in and did the same sort of runs. Slowly accelerating from 60-80 in 5th usually seems to do it so we tried that as well as doing some 4th gear runs and 2nd gear runs throughout most of the rev range. Even went up some hills while doing 1 or 2 high load runs.
The car runs great and like i said I've never heard it detonate even when I've got really high readings above 100. I'd like to do some more logging with datalogit on the weeked just to see if there's any knock to double check. But ATM I'm thinking either HC has issues or maybe my knock sensors are faulty.
But to answer your original question yes both occasions were on the street lol
What do you think? Youre the best person to ask I figure, yur knowledge of the power FC far exceeds mine :D
EDIT: sorry forgot to say. I usually log speed, revs, knock and wtr temp on the HC. when I play around next time I'll try just logging knock
Edited by 89CAL
yes try just logging one thing instead of lots of things
there is no logical reason hand controller would see knock differently to datalogit
and make sure you arent using both at the same time as its a shared bus
Hoping for some help on this one. I have an AP engineering Power FC for my R32 with RB20DET. I've had the Power FC for approximately 12 months and haven't had any trouble with it, until today. Upon driving on very light throttle the exhaust overheating light flashed once for about 1 second. So i thought i would check the peak values on the hand controller (i keep it out of site) and i discovered that the hand controller is stuck on the Apexi logo? The last time i checked it, a track day last week, it was working fine. Now it obviously still has it's tune because the car is running fine even with the Z32 AFM, 555cc Nismo injectors etc. Has anyone heard of this happening, is it possible that my hand controller is fried?
Thanks Paul. I'll do some more logging and see how i go
to properly test it make sure you log only advanced with the datalogit (no basic, aux, sensors or any of that stuff) without the hand controller plugged in.
Fixed. The plug for the hand controller was loose and only just making contact. I didn't realise the computer had been moved from its original position since having the roll cage and side intrusion bars installed. The unit now resides under the carpet on the passenger side and after taking a passenger on the weekend (a rarity) it must have been knocked loose.
  • 3 weeks later...
  • 4 weeks later...
hi guys i am encountering a problem. i have a rb20det in a 1983 mitsubishi galant (sigma) and i recently changed the stock ecu to the power fc djetro. it was tuned and everything but i am realizing the the rev limit is not saving when the car is switched off . i did a test and set it to 4000rpm on the hand held controller switched off the car, started back and it set back to 8000rpm. any help would be appreciated i went through this post and also through http://paulr33.com/. but i still cant find an answer. i looked at all the wiring diagrams i could google and everything looks like it is wired correct . next question will the tune as well be erased or it is it just the rev limiter . thanks in advance
the powerfc updates the tune in real time, and then when you key off, commits the changes to NVRAM
in the powerfc FAQ there is a section on this exact issue, search in the FAQ for "ECCS" and youll find a section on how to correctly set it up
on your car, as youve done an engine swap, the ECU isn't given enough time when you power the key off, so it doesnt get enough time to save to NVRAM, thus any change is blown away
the ECCS diagram shows you how it should be setup and how it needs to be wired in
Hey man,
Just reading over all the FAQ and so forth.
It says that the AP Engineering Power FC is not sold new anymore and I have an R32 GTS-T...
Is secondhand the only option for me?
James
yep 2nd hand is your only option
you can buy a 2nd hand PFC rb20det version and the new version EL hand controller however
i would do that if you find one without a hand controller
I think I'm gonna go Haltech Platinum Pro...aussie made...aussie tough...newer...more advanced etc etc
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
