Hi Paul
Just a question about using Datalogit on the PFC
Can settings be password protected so no adjustments can made at a later date with the normal hand controller .
Have been trying to increase my boost slightly but will not exceed 0.54bar .
PFC and EBC kit fitted and tuned by a tuner with datalogit.
I do not wish to return to this tuner if this is the case as we had a few issues.
Any help on this would be appreciated
Cheers
Ike
Hi Paul
Cheers
Ike
Its ok mate I have sussed it out
a big update today;
Added FC pro djetro doesnt exist
Added fc pro pics
Added air temp replacement sensor
Added map sensor list
Added other ecu alternateives
Added updated order delays
Removed bankruptcy at the top notice
Added keep the pfc faq alive
Added oem top and side injectors (latency) under Injector Changing
Good on you for getting and keeping this going Paul. Thanks.
I have a question I couldn't see an answer to. My HICAS light comes on after about 25km of normal driving. How can I check for a code like in the stock ECU? Is it pointless anyway cos it will just say HICAS error or can I get get more info?
Thanks.
Thanks.
hi adam,
the only thing i can think of would be to put the stock ecu back in and see how that goes.
if it doesnt fail on the stock ecu then pfc isnt doing something the stock ecu is
i had this issue with a-lsd in my r33. it was relaying the TPS signal to the alsd puter in the boot, but the stock ecu did
original site restored, so we dont need the other mirror any more
the vct kick off point cannot be changed with the hand controller
the default is 4700rpm on the rb25 r33 model
My power FC crapped itself and needed to be repaired.
It kept on reverting to the base map and was not saving certain settings after a tune.
I had a loose HC port and apparently the chip was fried.
$400 later and I am waiting for the unit back from Access with a new chip, and hopefully all problems solved.
Unfortunately the tune was lost (bit disappointed they didnt save the tune before replacing the chip), however I expected this and asked my tuner to save the last tune before I took it in - maybe a good point for anyone that has to send theirs off for repair.
Can anyone confirm what this $400 would have replaced? I could not get a definate answer whether it was a major component of the unit (i am not very electronically minded) or if all I got was a small chip. The reason I ask is that I am just curious whether i essentially have a 'new' unit, or if most of it was retained and I have just a small bit replaced.
Cheers
if you've lost the tune data, then they probably replaced the nvram chip
this is the chip that stores your tune data and settings when the power is off
if its damaged or cooked it might not update itself with any new changes, which is what u were seeing
So this is a fairly small component of the unit?
Any chance damage to this would cause an unusually high battery draw? Usually my battery goes flat in 2-3 days, but since I took the PFC out to send it away the battery hasn't gone flat (the doors still open with the alarm remote after a week - they dont usually last that long)
I have been reading everyones guides(especially paul) and been a great help so far thanks heaps.
had my car tuned with powerfc and most things are fine but if i coast up to lights or stop sign in neutral the idle sits at about 1200rpm but then when i come to a complete stop it drops back to usual about 750rpm. anu ideas on what is going on? other than this idle is prefectly stable all the time.
cheers
id say aac valve could need a clean the gasket could be toast and leaking a bit
thanks for reply. the only thing is that it only started happening after i put the power fc in...it jumps between 1200-1400 then drops back to normal. with stock ecu i could coast to a stop and idle was fine, thats what has confused me.
I got the power fc D-jetro on a GT-R R33 ...The stock load points are maxing out at 1 bar of the T88 ...Is there a way I can rescale the load points on the D-jetro power fc ?
It came with two apexi/denso map sensors
Edited by SR beast
hi,
there is no official english manual. that link pointed to a english version for the integra so some of the features were irrelevant
ive managed to source english manuals for the fc pro software which covers all the main controls in the powerfc so there will be a big update to the power fc faq coming soon with all the legit english instructions
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....馃ぃ) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
