hi,
there is no official english manual. that link pointed to a english version for the integra so some of the features were irrelevant
ive managed to source english manuals for the fc pro software which covers all the main controls in the powerfc so there will be a big update to the power fc faq coming soon with all the legit english instructions
Great work mate, look forward to it.
cheers,
noob question, i got a stockie r33 gtst at the moment, and intened to get a 3" turbo back, fmic, and an ebc in the next few months. I dont intend to go furhter than that for quite some time ... is a PFC really required to retune my car to these not so huge mods or would a safc do the job?
more benefit getting a PCF, lotsssssss
are those benefits quantifiable? As in really noticeable with the PFC just with those mods listed above as compared to with a SAFC? Noob q again :)
You may be able to get by with a SAFC, but in all honesty you're probably better off to save your money and wait to buy a Power FC when you can afford one. With those mods listed you should be able to get close to 200 rwkw with a Power FC, but would struggle to get those numbers with a SAFC, because you cannot adjust the timing. Later down the track when you want to put a larger turbo or injectors in, the Power FC will cope easily - where as, you'd have to chuck the SAFC in the bin.
I find having the hand controller is an invaluable tool also, as it will display peak values on Engine knock, RPM, injector duty, water temp, etc. So at any time you can have a quick glance to make sure the engine in operating within limits.
I realise a Power FC is $1000 more, however the extra tuneability/features are well worth it.
Thanks for that mate. Sounds like its well worth the wait for a PowerFC then. Cheers.
Hi,
Is there some way to lock in a rpm limit, for when a car is at the exhaust shop, or something like that?
cheers.
Yep, think its under settings>rev/idle
  • 4 weeks later...
I'm having the hardest time matching up a handcontroller to an AP Engeenering pwr fc, the pwr fc is for a RB20det (R32) and the model is simply 99i 0029
the handcontroller that is avalible to me is model no FCC3 026 - 12009 any oen help a bloke out? totally stumped with the AP Engeneering model, . the hand controller is up for sale so i need to be quick, cheers Damo
Anybody has tried using RB20 AFMs for RB26?
yes several people have, nismo ones are easier are direct swap with 65mm kit
How do I set the RB20 AFM setting in PowerFC?
its the same as rb25, you choose RB25-80mm in the menu
Are there any difference in the setting with using RB25 AFMS?
Any advice is appreciated. THanks.
rb20 is the same as rb25
Thanks for the quick reply Paul.
Just got my PowerFC and still not familiar with all the features.
just needing to confirm that a 415-X001 pfc hand controller will work iwth an ecr33 rb25 pfc yeah?
the faq tells you how to work out which model to get
the faq main site is down dont know how long for you can view the pdf mirror in my signature
you need to find out if its ECR33 PFC or RB25 PFC
the serial # on the side of the case will tell
then from that you can work out what hand controller you need
from memory RB25 is the older one and needs N001
and ECR33 is the newer one and it needs X001
The FAQ has moved to its new site, the URL is in the first post or you can reach it here
http://paulr33.sauvic.com.au/docs/powerfc-faq.htm
Ermm that link doesnt work but this one does -> http://paulr33.sauvic.com.au/docs/powerfc-...powerfc-faq.htm
lol silly paul! :P
updated
fixed injector correction wording (the numbers & calcs were correct but wording was wrong)
added apexi documentation extracts (they are in blue backgrounds in the doc)
added apexi documentation extracts for boost control notes
added apexi documentation extracts for injector correction notes
added apexi documentation extracts for airflow meter change notes
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....馃ぃ) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
