Hi Paul,
Got a question that I'm hoping you'll be able to answer for me. Would late model R33 GTS-T's (post sep 97, early 98) use exactly the same PowerFC as the earlier model R33 GTS-T's?
My reason for this question is related to the change in CAS on the late model 33's. I've basically got a set of "series 2" Tomei Poncams with an R34 CAS to match. I'm now wondering if this CAS will work with the ECR33 PowerFC that I soon plan to install.
If all PowerFC's for the ECR33 were the same then in theory it should work as the post sep97 r33's came out with the different (r34 style) CAS. *fingers crossed*
Thanks!
P.S. I have called a couple of tuners and they're not sure either.
hi damuscat,
The R33 uses the same model PFC wether the car is 1993 or 1998 R33 (inclusive).
They all use and run the same stock ecu (map changes however) but its the same control unit.
The 98 R33 that uses the R34 CAS runs the same logic and controls so its fine with a normal R33 PFC.
I know of a 1998 R33 in melbourne that runs a normal R33 PowerFC fine with no issues.
hi damuscat,
Awesome! That'll save me a lot of trouble. Thanks for the lightning quick response too! :(
  • 3 weeks later...
Updated today
added rx7 injectors to injector change table
corrected a version mismatch which brought back the old incorrect injector change calculation text ( but the math was correct )
Just purchased a PFC With a tune on it already.
I tried playing around with it but made my car worst than it was already.
I know it needs a prof tune but i want to attempt to make it work first.
Fuel is my main issue at the moment. I played around with Accel. Inj Time. No idea what it was. Whatever it did, the car doesn't even idle properly anymore. It just goes up and down on the rev gauge but staying under 1000. It wants to cut off but doesn't.
Also, it wont go any higher than 3000rpm. but on the way up there it just rumbles and doesn't do it very smoothly.
Before i mucked it up the revs climbed smoothly but once i let it go and it went under 1000rpm and would sink and almost turn off but would steady itself in a few more seconds.
Any ideas what section i should look at?
Pitty there is no english version of the manual.
Thanks in advance.
At 1st glance, sounds like you've selected the wrong AFM.
Check that setting first...assuming you know which AFM you do have,
Also, if you don't understand what the injection timing is for, stop what you are doing right now ! Seriously.
Best would be to reset all the settings and go and get it tuned.
Resetting it will make it more than drivable as long as you take into account and basic mods like injectors or AFM's etc.
Thanks in advance.
hi,
what are you trying to achieve?
have you juts got and installed the powerfc?
ok ive just re-read it, using someone else's tune is a bad idea and great way to kill your engine
its not idling properly as the tune is from someone else's car
the first thing you should do is follow the correct install procedure (in the faq) and reset the powerfc
the tune on it is useless and you should start from scratch. this will make it idle correctly then you can get it tuned
Hey Guys!
I have an Apexi Power FC in my Gizza. (sorry not a skidline)
I always have a knock of 1 on idle, but may max know under full acceleration is usually below 10.
Max knock i ever had was 64, when a did a super shit gear change :)
I just wondering what sort of figures your Hand controllers give you?
THanks ,
Mike
Hey guys i need some help i have a POWER FC for my evo 6
and i also ordered the WRONG boost controler kit for it
now is it posible to re wire this controler to work with the power fc? like just the end plug?
or will i have to swap it with some one?
Hi Paul, a similar question to the above:
A friend has the Power FC boost controller kit for the R32 GTR. I have a GTST R33. Will I be able to use his kit with my PFC?
this will depend on the # of pins on the socket and your powerfc
both should have the 5 pin kit but check (there is also the 3 pin kit)
the socket next to the hand controller port is either 5 or 3 pin
check what yours has (should be 3) then check what he has (should be 3 also)
if they are both the same (either 3 or 5 pin) then its fine and direct fit
Just installed the PFC this morning but i had problems during the initial stages when i first start up my car. Based on FAQ, i let it idle the 1st 10 mins without any problems then when i switch on the Aircon, the engine started to hunt up & down non stop. I check the sensors to see what was wrong but no problem indicators was shown. When the aircon was switch off, the idling was perfectly normal. I tried to initialize it then doing the same routine few times but still have rev hunting with a/c on. The engine felt like the a/c is cutting in/out continuously.
Then i realize that previously my mechanic told me about my idling valve needs changing because the screw to adjust cannot be turn due to the plastic gone all flat. I change it immediately (2nd hand) and Voila! it runs like a dream now. No hunting whatsoever. Did a 15 mins idle then then turn the A/C on and took it for a blast. Currently happy with the base map and will do a proper tune once i get the Datalogit software.
Hope this would help those who has problems during installation time.
Edited by driftmeister
why do you mean it's in power fc? do i need to go to rx7 forum? or there is a tread in here for special tricks?
sorry i mean its in the powerfc
as in the screen part # and how to do it
have a look
(url is in this thread first page or my signature)
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
