Hi
can someone advice me how to restart apexi fc??? i have tryed to unplug batterys but there is no changes... please help me
hi
its covered in the powerfc faq but to reset it ;
ETC, DATA INIT, choose YES, press NEXT
power the car off
next time you power the car back on perform the self idle learn procedure (also in the powerfc faq under install)
hi driftmiester,
no it wont, its just normal detonation occuring
follow the standard guidelines in the powerfc faq on how to debug knocking
no the z32 afm just allows for more tuning resolution and nothnig else, its the same size as the standard rb25 AFM so it wont add power
Thanks heaps Paul. You hv been a great help.
Im now saving up a Datalogit & probably a wideband, this way i will be able see more stuff with the laptop. Currently using the Apexi Turbo timer which also shows the A/F ratio but not very accurate.
Just wondering, did apexi make power fc's for automatic skylines?
no there isnt an auto skyline version of the powerfc
there is for toyota however as lots of toyota's are auto and i guess the code/logic is maybe a bit easier
hey paul, i just recently had a PFC + HC intstalled and tuned on my RB25DET, it was ok for the first week, but now im getting knocking anywhere from 80 to 130 when i plant it.. the weather has got warmer, and at night time i dont get much knocking at all if any.. is there any way i can fix this?
cheers..
Edited by EVL-R33
cheers..
hi,
just read the faq, its covered numerous times
look under technical issues
Hi Paul
Just checking whether under the SETTING for AIRFLOW, does the Power Intake refer to those ER34 who has changed to after market filter cone type? A friend of mine read it somewhere in the Japanese version manual indicated this. Just want to double confirm.
Hi Paul
yes you can choose the power intake when you change the airfilter but its not required
and it probably wont make any difference, i dont know any one thats done it and gained anything
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
