Hi Paul i received my Power fc today and was wondering if you can tell me where the stock ecu is located on a R32 GTR. I've had a good look on the net and come up with nothing.
Cheers
its located in the front passenger foot well, behind the panel
just remove it and youll find it there
can anyone point me to a site on DIY separating the hand controller so i can rewire and mount the screen and buttons separately, ive seen pics in the FAQ but no links...thanks
theres no real DIY on how to do it the screen is connected to the main FC board with a 20 pin connector
if you need to extend this connection you could use an IDE cable that's long enough as its fairly dense and has 40 wires so you only need half
the guys on the rx7 forums have done this and thats all there is too it.
Im about to purchase the sep boost controller for my power fc i was wondering if the power FC and the boost controler add on has more features then the AVCR ? or the same ? i read the AVCR has a scramble feature with the press of the bottom you can have more boost added can this be done on the power fc?
i also read that the power FC can hold 4 maps where as the avcr only holds 2 is this correct?
Im just wondering, if the revs are hunting on idle is a good thing for the engine? (sounds cool though, rotational idle lol) Would this happen cause the timing is overly advanced. I got told by a tuner that the power fc comes stock with advanced timing roughly 20 or 30+degrees to suit Japanese conditions. I also did get bad knocks, worse one was roughly 100knocks. Dont know if its true but stock ecu is back in and my timing is true too with no misfires. Took the power fc out just to play it safe for now as i dont have money to get it tuned.
Hi Paul
I notice my idle sometimes drops really low when blipping the throttle or when the car is warm and restarted after an 1 hour. I followed the installation accordingly. Is there a vacuum leak in the system?
hi robert,
the avcr boost control system uses the same solenoid and pressure sensor and probably the same main logic code to control boost.
both can set duty and vary the duty cycle for the solenoid to control boost. the powerfc has a safety fuel cut if boost rises 0.25kgcm2 over the target boost setting
so it has an extra insurance policy built in if you use it.
the avcr has two extra features that i know of over powerfc boost kit
- gear judge - the powerfc does not have this
- boost screamble - the powerfc does not have this
the powerfc has 4 boost 'profiles' however - each profile has its own boost setting in kgcm2 so say 0.85kmg2 and its own corresponding duty
so you can hi / low boost profiles and vary the duty cycle etc to change them you need to use the hand controller and select the active profile via SETTING, BOOST
all in all the boost control kit is probably fine for most applications and setup and its cheaper too,. just without the screen & gear judge
hi,
it wouldnt say its bad for the engine but i would look into fixing it however
the timing when the powerfc is running the idle control is locked and you can't vary it from any settings
so if you run mega spastic ign tming (like i do) the idle should be locked to 15deg (with correction) and you can just magically set it to idle at 22deg for example.
an offset CAS sensor will cause this however so make sure your base timing is correct. if you do MONITOR, 1 CHANNEL, REV, what do you see at idle?
the stock maps on the FC arent to aggressive they are pretty conservative but they do usually knock if you just install the ECU and trash the pants off the car.
the solution is to either use the temp IGN adjust to back out some timing, use some higher octane fuel or get it tuned properly
1 & 3 are the recommended solutions - theres no need to remove the FC, its a stand alone ecu just make changes as needed and away you go
Hi Paul
do a standard check for any obvious things and even try touching some of the air lines to see if it varies the idle note
also check the AAC valve (theres a howto thread in the tutorial) and give that a clean
low idle rpm can be caused by a few things;
dirty AAC valve
low battery voltage or strange dwell settings
low RPM setting in SETTING, REV
airleaks or dodgy connections for the airlines
Thanks for your help paul
now i just have to decide what to get i like the scamble feature and i dont think i will have more then two boost settings just normal and high but pressing a button for scamble could be fun to but yeah we see i like the sounds of gear judge to im happy to give away 2 boost settings for these two features
wonder why apexi did not add them seems stupid but none the less thank you for your help once agian
dirty AAC valve
Thanks Paul
I guess it could be a dirty AAC Valve too. Going to get it check soon. Cheers!
looking at getting PFC for 32R.. is there a serial range that better than rest ie. PFCGTR33010-0102 vs PFCGTR33020-1852.. later is newer but i had read somewhere theres a firmware bug on these model.. any info wud be appreciated
PFCGTRRB26L should be the newer style powerfc with N003 hand controller im pretty sure (FCC 3)
the older style may be;
PFCRB26 and its probably with N001 hand controller which is like FCC NT or FCC 1
to known differences to this date
the misfire well known bug still appears to be present in the latest rb26 code apexi offer for the rb26
cubes got a latest new rb26 pfc from apexi and it was 8.x something with the bug still present
Hey Paul,
I just read there is a VCT and non-VCT PFC models for the RB25DET. Is this true? If so, how can I tell which mine is (second hand, no box). I don't know the model code right now cos it's at home.
Edited by sl33py
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
