i have it - jap and eng version
whats up ?
Software was purchased, installed, registered and connected OK to my ECU without a hitch, however when I tried to connect it to two other 'pexi ECU's it failed to establish a connection.
I spent a fair bit of time trying to nut it out and it appears to be just the other two ECU's that I have an issue communicating with. So I guess my question is: Is the software only licensed to run on one ECU, or is it the two (non-communicating) ECU's being of a different model/type?
The software works seamlessly with my R33 GTR, so my belief is that the issue lies with the fact that the R34 GTR and R34 GTS-T's Apexi ECU's are not compatible with the R33. The only way I have to determine if the problem lies with a license issue or with a software version issue is to get another R33 GTR with the same ECU as mine (about as easy as it sounds).
This is where you come into it :D . In your travels have to come across the quick answer to this question?
some updates tonight - has been a while...
removed the user content section - it was crap
updated version info & version matrix
updated "does the unit work on auto cars"
updated manual links for user manuals
updated "what is the fc pro & do i need it" - included identify fake fc pro versions
updated "How does the AVC-R compare to the PowerFC boost controller kit?"
good update today
updated "I have the older PowerFC that did not come with a hand controller can I buy a new hand controller separate and use that?"
updated "Does the PowerFC have limits?"
updated "Help! My car doesn't start once I've installed the PowerFC"
updated "Where can I get my PowerFC tuned and how much will it cost me?"
updated "My idle is really crappy and it hunts around a lot when on idle. What can I do?"
updated "My fuel economy is terrible and I just had a complete tune, Whats wrong?"
updated "Boost display without the Boost Control Kit?"
updated "Hybrid Apexi PowerFC models and mix n match models, can it be done?"
updated "My Skyline R32 GTR has a wierd misfire problem, what's wrong?"
updated "Is there a replacement hand controller screen?"
updated "I have fried my PowerFC. Is it fixable?"
updated "How do I debug knocking, how can I make it go away?"
updated "PowerFC Pro - Launch Control"
updated "I want to go EPROM/Firmware hacking, Tell me how"
This is where you come into it ;) . In your travels have to come across the quick answer to this question?
this is certainly possible - have a look at the product matrix to find out if its supported by your version of FC pro & cable
alright i have now installed a power FC into my car and im having a issue im not sure if it due to the power fc or what
when i give my car the boot then take foot off the accel and put on clutch now and again my car will stall but soon as i let foot off clutch starts up again (like push starting it)
has anyone had this issue mind you it is in a evo so i doubt alot of you have
hi robert,
this can happen if you dont do the self idle adjustment properly
can you confirm you did this correctly?
also i assume you have std bov etc and not an atmo unit ?
if its blank unplugged or loose cable
if its locked on the apexi logo wrong hand controller version
if its locked on a blank screen (but lit up) then loose connector, damaged connector or damaged hand controller
Hey,
I have a RB26DETT FC D-Jetro on its way from nengun and i have the field one touch connecter from greenline. A mate (the_mafia) is re-wiring it to suit my rb20det r32 gtst. He has done the conversion with a normal fc but never djetro.
My current mods
3" turboback
2.5" split dump
GCG Highflow Turbo
Turbosmart boost T
HKS Pod
Walbro Fuel Pump
Fuel Pressure Reg (going to be removed with ecu install)
Splitfire Coilpacks
Plazmaman Forward intake plenum
hybrid fmic
plazmaman piping kit
when ecu goes in (already have waiting)
GTR injectors
3-4" intake pipe
Now we have extablised i can use a vacuume line from under plenum and T off to 2 map sensors. What im wondering is i have read the map sensors need to be spliced into standard loom for airflow meter... so do we cut off plug, and just splice 2 new wires to each existing wire in the airflow meter loom.
Also air intake temp sensor. Where does it go... have been told this will make tune much easier. So basically is there an aftermarket option (bosch) or something that is cheap or should i source one new from nissan?? Will i need to weld any nipples onto piping anywhere or what?
And now for the acc valve. I have a hose going from that to my intake pipe (behind my afm) for now and i have been told i can just put a little breather filter off the valve and leave it at that with the fc... and it will work fine, is this true.
Factory oxygen sensor... should i replace it... i have been told they should be done every 40,000km and my guess is mine is still factory one. I have also been told i wont need it with djetro and it would be a waste of money... in that case can i plug off the dump pipe or should i just leave it or should i replace it.
thanks alot if you could answer these questions. Yes i have read the faq but i could not find too much relating to my issues in depth.
cheers, Leon
Question
*2x R33 GTST Series 2 Skylines
Car A: Has Apexi PFC and Z32 AFM
Car B: Has stock ECU and stock AFM
How simple is it to swap these 2 items between cars as car A is going to be sold and taken back to stockish state. Can we just simply unplug the wiring harness from the ECU's, swap them around and plug right back in and should be fine to drive?
*Cars A and B both have stock turbo's and almost identical modifications (FMIC, 3" turbo-back, fuel pump)
Also, unplugging the PFC and moving to another vehicle... with this retain the tune or reset all settings?
Cheers,
Ryan
Question
Cheers,
Ryan
if you do a direct swap one for one it should be ok - the worst is it wont idle, if it doesnt then youll need to do DATA INIT to do the self idle adjustment (you will loose the tune). the tune is always retained even with power off and unplugged. its only erased if you do DATA INIT
Hey,
My current mods
3" turboback
2.5" split dump
GCG Highflow Turbo
Turbosmart boost T
HKS Pod
Walbro Fuel Pump
Splitfire Coilpacks
hybrid fmic
GTR injectors
3-4" intake pipe
cheers, Leon
:D Help please
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
