Hello,
As i have stated befor i have rb20det with a ecr33 gtr power fc d-jetro
Now i just ordered a boost control kit for the fc. As far as i can understand from reading the boost control solenoid has a plug on it, which a cable plugs in and that cable must goto a standard boost control solenoid. Well the rb20det does not have one?? What can i do. Where should i plug this in or splice it in. I have checked most plugs in engine bay and none suit this plug. Pic is attatched.
PS. the extra map sensor they gave me aswell as the extra cable.... should i just keep as spares.. cause im assuming you dont run 3 map sensors on a single turbo engine!
hi leon,
the ECR33 and BCNR33 powerfc have a 3 pin boost control kit port on the side of the PFC
this is for the map sensor for the boost control kit (do NOT mix this up with the djetro map sensors).
the boost solenoid gets power from the existing wastegate solenoid wiring which is used with the stock ecu.
from memory the ECR33 and BCNR33 had this on the wiring loom as "wastegate solenoid" but the RB20 loom i don't think has this wiring.
If it does then you connect the solenoid to this "wastegate solenoid" wire and the ground to chassis ground.
If your RB20 loom doesn't have this wire then you will need to run it yourself. The power wire nees to run the ECR33/BCNR33 PFC wiring socket on the actual PFC - check out the wiring diagrams to find out what PIN # it is on the PFC and then get ground from chassis ground.
The boost solenoid uses a 12v power and switched ground to turn it on and off - so you can't get it wrong, if you do it just won't work
thanks alot... i half get that, i think ill wait for the_mafia aka pacey to help me out this wkend, but this should certainly be of help.
Just one thing though... were does the map sensors goto now? Do they have to be spliced in with the boost controller map sensor?
i dont know - ive never setup a djetro PFC but i think it should come from the plenum
and i think the boost signal should come from as close to the turbo outlet as possible
Is there somewhere that tells us the "normal" range for sensors? I have been looking through the FAQ and cant find anything.
My car just started hunting badly all of a sudden and idles at 2000rpm when cold, 1500rpm when warm
A/C on or thermo fans on seems to stabilise hunting a bit.
I cleaned AFM, cleaned AAC valve out and then I checked sensors in the PFC hand controller
AFM sensor goes from about 1.3V (idle) to 2.4V at about 3000rpm (stationary)
Air Flow is about 1400mV if I turn that on with the monitor function.
O2 sensor is at around the 1.0V mark too and when hunting ranges from 2.72V to 4V
I replaced the fuel filter a few days before the problem started and it was really dirty would this be a possible problem?
I also went through a big puddle of water and the car stuttered...
Thanks
the nissan ECR33 service manual should tell you the voltage range of the sensor - check out the sections covering consult diag - it shows you how to do each diag and what the ranges should be - of course you can't do consult diag but it will give you an idea of what acceptable levels are.
the 02-1 sensor shouldnt go past 1.0v its a slow and narrow sensor, it should only go between 0.0v and 1.0v
any sensor that is out of range will be highlighted with a black background in the ETC, SENSOR SW/CHECK screen and the engine check light will also be on (orange engine icon) on the cluster
hey mate,
Me and pace got my car (rb20det djetro) up and running on satrurday arvo. Just one problem. Sensor check is coming up error with TPS sensor, We tested the tps with multimeter and it works fine. Do i need an rb26 one?? or whats the go there... the check engine light is on 24/7
Paul,
My mechanic says there's a difference between PFC's made for the R333 GTST S1 and the S2! One designed for internal ignitors, the other for external (can't remember which he said is which). He's going to find out for me today. The PFC I have came off a S1 and mine is an S2....
Paul,
hi,
this has been done to death and covered a dozen times
there is no difference between S1 and S2 - the ignitor differences are on the engine side, not ECU side
so S1 ECU can be used on S2 and vice versa
There is no PFC for S1 and a seperate PFC for S2
hi,
Whats the difference between R33 RB25DET and RB25DET NEO R34 PFC?
quiet a lot
there NEO has some extra sensors, controls and features
things like traction control etc make it in-compatible to a std RB25
i suspect you could piggyback / hack out those items
quiet a lot
Thanks Paul - I was just curious
Another question - whats the easiest way to knock some timing off with Power FC?
I found 2 options but both are as confusing as each other
hey mate,
Hey, sorry to be a pain in the ass but... ^^
:P
SETTING -> INJ/IGN Adjust
Press DOWN 3 times and you will see -3 for IGN ADJUST.
This drops the IGN map 3 degrees timing temporary (will reset when car is powered off).
HI.
Great FAQ!
But is it possible to get some more info on all the different settings? Not maps, revs etc... But the stuff in "settings 2 and 4" in the FC edit program...
what effect they have and more on what they do. Right now im still a little afraid to begin playing with these settings.
update today
updated some text on the other versions and version matrix
removed some of the junk in the menu roadmap
removed some of the rare crap in menu tree
fixed up the formatting so its paginated now (easier to read)
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
