updated again:
fixed missing image
fixed spelling mistakes
fixed grammar mistakes
added hyperlinks for each section
added section split based on content
added self tuning - fuel economy
added info on changing airflow meter
added info on powerfc tune protect
expanded info on tuning options and expected results
do they release slightly differant maps in the diff versions of the pfc/hand controller maybe ?
I was comparing my ign map to the one in the faq, and in some points (outside of the first 10x10 range) they were off by like 10 degrees. I also compared them to the ign map in the FC PRO software, they was differant as well.. ??
Mine is pfc v 5.11, and hand controller v5.01A (might be the other way around)
Wered you grab the stock map on the faq from ?
as far as i know the stock maps don't change very often
i havent at least heard they do. they were taken from my tune
but i may have done it before i did factory reset so they could be a "tuned" ign map. when i get datalogit, ill copy mt tune. reset to factory defaults then upload the defualt maps to my site and then restore my tune and upload that as well. ill expand the powerfc faq a lot when i have a working datalogit
added boost control pics, info and wiring
added djetro harness and wiring and manal
added datalogit specific extra features
added datalogit logging options
added datalogit additional functions
corrected spelling mistake of my name
corrected double up paragraph
updated again:
added airtemp sensor on unsupported car info
added powerfc inside cover photos
added reflashable powerfc info
added custom hack / diy / hand controller holder pics
added basic hand controller use
added checking sensors
added checking functions
updated install info
those 2 manuals are old as the hills and are for rx7. They are also the older powerfc so its not upto as the japanese SR20/RB25/RB26 manual.
it comes off the main wiring haress which i think is a digital output from the gearbox somehow, ill find out
It most certainlly a gearbox feed... The only other alternative is the ABS sensors but it still works on non-ABS skylines so it must be a gear box feed....
Plus the skyline has a digital sendor to the dash display....
hey guys i have a question for those in the know
because the nvct cam timing is constantly variable on the NEO rb25, can the PowerFC be mapped for this function, or how does that work?
with the r33 rb25 its either full advance or full retard no inbetween. and is activated by a simple on/off switch in the ecu at the desired rpm.
anyone know how the powerfc and rb25neo nvct perform?
is it completley mapable throughout the entire rpm band or whats the go?
no idea but if you find out let us know, will add to powerfc-faq
the vvt on the rb25 (33) isnt controlable and its automatically controller by the powerfc emulating stock ecu functionality. you can see it turn on and off under check sensor / sw but its not controllable or editable in map form
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
