Hi Paul,
Absolutely awesome FAQ!
Just a quick one, have an ECR33 PFC, does anyone know what the "VTC" stands for in the Sensor check? At first I thought it was a miss type of VCT, but now i don't think it is.
I'm running a PFC on my 95 ECR33 series 1 so no A-LSD issue. I took my car to the dyno today and could not correct a a/f issue so I did 6 runs and all sucked hard core. Anyone have good info they can pass to me on how to richen up my fuel or even better does anyone have any maps I can use for cross reference? I have basic mods on my car, large FMIC, intake pipes and filter, down pipe, hks actuator, stock turbo and boost with power fc, 3" exhaust, bov.
All I'm really looking to get is a good picture of what my fuel and timing maps should look like along with where my timing advance and fuel cor needs to be at. I've been doing trial and error but all that seemed to get me was running extremely lean and shit numbers on the dyno.
Any help
Any help
hi vandrel,
why dont you get just go and get it tuned properly - then you wont need to guess and trial and error
pay a local tuner a good $500 and have it done properly. lastly read the PFC FAQ under tuning and advanced operation
it covers AFR tuning and IGN timing tuninig as well using the hand controller on the powerfc
added rb20 injectors
fixed 'what are all the menu items' roadmap - just fixed up some text
updated How much does the unit cost?
big clean up of "What other optional parts are available for the PowerFC?"
updated "Is the PowerFC Pro Discontinued?"
updated "What's the Apexi D1 Limited Edition Hand Controller?"
updated "I have the older PowerFC that did not come with a hand controller can I buy a new hand controller separate and use that?"
updated "Does the PowerFC run the whole car or do I need controllers for... (Aircon, Lights, ABS etc...)"
updated "Does the PowerFC have limits?"
hi vandrel,
i would love to drop it at a local shop and have it tuned but no one locally near me knowns what a power fc is let alone how to tune it. i'm not even sure if there's anything within a reasonable drive from where i am that could tune a power fc
updated "where can i get my powerfc tuned"
updated "how do i install the djetro map sensor kit"
added "advanced datalogit tuning - a how to guide?" - this is excellent
hey mate,
Just wondering with rb20det running a rb26 computer, have you ever had troubles with the knock sensor?? I have rang nissan and a rb20 and rb26 knock sensor are differnt, but they cant tell me whether they are phsyically different or diferent insides? My car is knocking real bad, but its real random, does it sometimes but not others.. i can hold it on limiter and knock to 20, then other times i will rev to 5k and it will knock 70??
any ideas.
Im thinking of using both a Haltech E11v2 and a PFC.
Plan is to keep the PFC for the monitoring of all the sensors (knock,temps ect) with the handcontroller and use the Haltech for the performance side of things.Also enable me to run with no AFM.
I could buy the Haltech dash but at a cost of $1800 its alot of coin plus it does not monitor knock.
I think with this setup im getting the best out of both ECUs.My tuner says he can wire it up no probs.
What do you think?
hey mate,
any ideas.
hi,
you should chat with Cubes about this, he has working RB26 PFC on the RB20 and has noticed some difference with the knock sensors
send him a pm and hopefully he can clear it up
What do you think?
hi,
do you have money to burn? it sounds like it
you would be mad to run two ecu's at once, what on earth for? to achieve what?
just to get rid of the afm? do you understand all of the differences between afm and map ?
hi,
I believe i stated why in my first post.
The aim is to use the PFC for monitoring everything and use the Haltech to control the performance side of things.
I have both ECUs(PFC in the car ATM).
again - why would you want two ecu's to perform one job?
why not sell the haltech? or sell the PFC?
both ECU's are capable of running the car and making everything work - the PFC is probably better at it
Hey paul,
EDIT: missed that bit in the guide. think i have the wrong model hand controller.
I have a powerfc serial number: ECR33 010 - 1452
And hand controller number : FCC3 020 - 11909 (I dont have a rotary hand controller do I?)
I couldnt find any numbers similar to 415 - X001 etc and your link to nengun isnt valid anymore (nengun seem to have removed all apexi gear)
Thanks for any help,
Bill
Just tried an install of a PowerFC on my R32 GTR, followed the idle learn process, but I get a real lumpy sounding idle from the start and doesn't get any better, revs don't hunt, and when i attempt to take off in 1st gear, car shudders and goes to stall making it undrivable.
Initially i thought it was caused by incorrectly following the idle learn process, but I've tried reseting the PowerFC to defaults and re-learning the idle process 3 times without success.
-I don't have any sensors highlighted in Black on the hand controller.
-I have set the PowerFC to not use the Boost Controller Kit
-Set BNR32 AFMs
Car starts and idles, just doesnt idle smoothly
Once I plug in the factory ECU, car idles and runs perfect.
Any help would be greatly appreciated :blush:
thats the correct PFC and hand controller for your car
FCC3 is generic multi version hand controller - it will work fine on ECR33 PFC
    • Would it not be cheaper to just spray nitrous?
    • I've got cash, it's the NA LOLS I'm after now Plus, I've had a few boosted cars, and it is soooo easy to turn a reliable car into a unreliable drivetrain eating money pit monster by just paging up and chasing more My power goal for the NC is to try for a reliable naturally aspirated 150kw or 200hp atw (I'm old, and the old naturally aspirated cherry of 100hp per litre is a goal that I would like to hit), no more is really needed for what I use the car for,  so a additional 5kw is what I'm chasing now,  that 5kw is about $3k away, I think....
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....馃ぃ) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
