very quick question
got mt PFC installed into my R34, ever since then my engine light wont go off the dash :) asked the tuner he said it's running fine etc and has no idea why it wont go away, he said the only time it goes away is when he loads a fresh map onto it but then comes back straight away ?
It's a default setting on the PFC, I think it's to do with the PFC boost controller. You need to go in to the hand controller and turn it off. If you where here I could do it for you, can't remember it off the top of my head. :)
Edited by Wogboy
its under settings then sensors the display for on and off in japanese so make it different to the knock setting obviously it might be on atm so just toggle to the other jap character
well it's getting the turbo etc done this week will have a look then :) if not I might pop in one day when im down your way for tafe ?
One thing I am curious about, is whether the PFC has 6 ignition drivers and 6 injector drivers.. or does it run semi sequential? Noticed the VIPEC plug-in board is only 4 drivers and can't find any literature anywhere about the PFC (although one would hope Apexi gave us the full 6).
You will probably find that it is batch injection, i know many ecu's have sequential but from my research when i was looking at getting one years ago the did sequential not many tuners would tune sequential, only batch.
That's it, like he said /\ /\ /\ :)
Hey guys,
Like ian_and1' s engine light being on from key on to key off. After mine has been installed i get TCS, SLIP and tne engine light solid on. and to boot the a/c doesnt turn on. Any ideas? I've reset the data and completed the 30min idle process checked nd double checked the Boost control kit. Any ideas?
Cheers
i like how you say "only"
if TPS isnt working, its a pretty crucial sensor
did the car run OK with the std ecu in? ie did it have the engine check light on with the std ecu?
i cant see why the PFC is pissed off, it cant read the TPS sensor, throttle body sensor
no idea why its not working - the sensor is either shagged or the wiring is mangled or something else is wrong
do you know of any other ER34 PFC users - do they have the same issue?
hmm is THR same as TPS - logic says so, youll probably find the SLIP system expects the TPS signal from the ECU
much like Active LSD does, the PFC wont know/expect this and wont relay the TPS signal to the other computer
so it fails, well at least in my case, thats what was happening
you are best finding another ER34 PFC user and ask what they did at install time
i think Dan666 has used ER34 PFC - ask him
I'm pretty sure that THR relates to a map sensor that only the ER34 has, sounds like yours has failed. This is the same reason we have trouble running the 34 pfc on a stagea because they don't have the sensor at all. If you have a look around the stagea section you can find the exact pin and voltage, its around 4.1v from memory that should be returned at idle.
Hi duncan thanks for the advice. Had a read through a few posts on the stags and theres alot of useful information there. Though I guess theres no real way to diagnose it until i have a known good TPS i can test out..
Any ideas why the A/c turns on but the compressor doesnt? also a/c turns on an off with the console switch in the sensor check on the PFC.
Cheers :D
updated
corrected - What is the "Power FC Pro" and do I need it?
updated - What does the PowerFC look like inside?
added - What does the "FC Pro" sticker mean? Why is it there?
Mythbusters ahoy!
FC Pro sticker means sweet f**k all
it does NOT mean its an FC Pro unit
Hey peeps, I have a problem with my pfc. I have a 33GTR and had the injectors cleaned recently. Before that, not a problem but since, the car wont start cleanly without accelerator input when warm. When cold it started ok for a week or so. But now its the same warm or cold. When cranking the inj duty is between 0 and 3. Not enough to fire it up. Now none of the settings have changed. I have done an init of the pfc and reloaded the tune and made no difference. Once I get it started then no problem at all. It runs spot on. The sensor sw screen shows nothing wrong. I plug the std ecu in and it starts straight away. Any idea's?
    • Thanks Pac!   I will reach out to them!
    • Yes, but 2 things of the top of my head, 1. Legalities of nitrous on a street car. 2. No chop chop. I fully understand that there's much cheaper ways to make power, and whilst a wet 50 shot is fairly cheap to install, bottle fills are expensive, and bottles always need to be refilled, and nitrous also has its own inherent issues with reliability, and tuning, from my experience of others using nitrous, it doesn't take alot to lunch a engine real quick if something goes slightly wrong when spraying, if I wanted a big chunk of additional powers, a spooly boy would make alot more sense, disregarding the additional engineering, supporting mods and other logistical issues of sticking a spooly boy on a car that came naturally aspirated from factory  In the end I'm not racing for sheep stations, and I don't really care if people make more power, or are faster than me, or spend less, or more than me, the only thing the car needs to do is drive around and make me smile, which it is doing now Really, I just want a shiny new intake to look at when I'm cleaning the engine bay, and of course, some more induction doorts, and maybe even that 5kw for that elusive 200hp cherry on top that I might get If the FAB9 intake plenum, TB and air filter box thing doesn't eventuate for whatever reason, Plasmaman do one, not as fancy looking, and a fair chunk of more cash is required when including the TB and other bits and pieces that are required to install it, but, it is another option that is available to me if FAB9 one does fall down (but I really, really.....really, want the FAB9 one though) TL;DR. You want what you want
    • Been so long since I have been here,seeing SDU is dead. I had that problem on my gtr in 2006 but luckily there was no engine damage,it was inspected by Hytech Engines,race bearings and extended crank collar put in and that was about it. Hopefully yours is sorted now.
    • Would it not be cheaper to just spray nitrous?
