im not getting spark on cylinders 1,3 and 5
is it possible that this could be a problem with my powerfc itself?
does the PFC have some kind of diagnostic to check this?
No it doesnt have a diagnostic for that.
Your best bet would be to eliminate the basics first. Dont do too much diagnosis at once though. Take small steps.
1. check your plugs, see if the dead cylinders have wet (fuel) plugs. Consider swapping plugs between working and non-working cylinders to eliminate faulty parts.
2. swap coil packs around, for the same reason as above.
3. Try another ecu, or a standard one if you can get your hands on one.
3. consider pairing up cylinders for waste spark operation. This is done at the ignitor. 1+6, 5+2,3+4. As dodgy as it might sound you can try using a single paper clip to bridge the ignitor inputs. You will need a circuit diagram for your model engine. If it doesnt start to fire the dead cylinder using this method it could still not be getting fuel.
Good luck!
yea, after allot of trouble shooting today it looks like some cylinders might not be getting fuel
so i'll be checking that tommorow
I would assume that would be an ecu or injector wiring harness problem as the injectors are batch fire (3 at a time) would pay to check which injectors are wired together before you go pulling thinghs apart though is it may be different ones to the cylinders not getting fuel.
just checked the manual and i cant figure out what ones fire together, on page 351 it has a heap of technical things to check to find the problem, if you dont have it already do a google search, its around 460 pages and well worth downloading.
anyone know which 02 sensor is "02-2"on the sensor check screen mine is faulty and i got a rear 02 sensor so im hoping its the rear one can amyone comfirm? i tried unpluging it and looking bck at the power fc and it was stil giving a reading on both
yep the vhost that holds the PFC FAQ is broken
im trying to fix it (its not my server)
if i cant fix it i will get it moved to somewhere else so wont be down for too long
i still have the data so its not lost
new hosting is here;
http://www.paulr33.com/powerfc-faq/powerfc-faq.htm
it may take a few hours to propogate via DNS so if it doesnt load, try in a few hours
please be patient, it is still uploading so the images/links probably wont work for a few hours
Updated PFC FAQ
-updated Apexi PowerFC Wikipedia articile and PDF Snapshot
-updated Apexi PowerFC EL Hand controller and incuded video (thanks John)
You suck, you got me all excited thinking that the EL hand controller was all new and did something good, but it dosnt :P
yeah it looks the same as the normal FCC3 hand controller, just EL instead of backlit LCD
im yet to see one working in the flesh, the one on the demo video is just a screen loop and not a real unit in operation
