yeah what he said^^ fc tune doesnt seem to be available, and i read copilot isnt very good..But it would do, as im not doing any tuning really just need it for basic map switching..
I have searched and found numerous DLs ..but nothing that wants to work..I thought there was one on your site but if there is i cant find it..
I been searching for 4 days man..
i downloaded co pilot but dont have datalogit cable so can only load the software and look @ it
do you have the datalogit software and cable
Was going to get the HAKO cable, which i beleive would work with copilot...
EDIT there was another DL here from 2003 that i attempted but cant open HD1 file yet ..not even sure if its right..
Edited by Arthur T3
Have a power Fc now and wanted to test to see if it works.
Plugged in and initialized.
All seems good except "Engine Check Light" was on throughout the power on.
Is this a problem undiscovered by my Remapped access auto (blitz) ecu or a problem with the power fc?
Thanks
if all your doing if putting ignition on but not starting i think that's correct you should get all dash lights warning and not
Sorry, my mistake.
I meant, ignition on, reset the power fc, then turned ignition off, then back on all the way to start the car.
Then the engine warning light remained on and the others turned off.
Thanks
the engine check light (orange engine icon) comes on when a stock sensor is out of range, disconnected, fault or broken
view the sensor that is causing the issue by looking at ETC, SENSOR SW CHECK and look for a sensor with a black highlighted name
of course if you had have read the PFC FAQ on page 1 you would have known that already
on cars such as R32 and RX7 they do not have an engine check light (orange icon) and use the exhaust overtemp light instead (red CAT icon)
so if you have HR32 then its the same deal, the light is used to advise you of a stock sensor out of range, not working or mangled
  • 4 weeks later...
In electronics, fall time (pulse decay time) \scriptstyle t_f\, is the time required for the amplitude of a pulse to decrease (fall) from a specified value (usually 90 percent of the peak value exclusive of overshoot or undershoot) to another specified value (usually 10 percent of the minimum value exclusive of overshoot or undershoot). Limits on undershoot and oscillation (aka, ringing or hunting) may need to be specified when specifying fall time limits.
Paul,
Have you ever had any problems with the hand controller giving false readings or causing the car to knock
Mine got looked at today and on datalogit its fine on the map watch, Knock was fine
But on hand controller I get high readings at the same load points
Have you heard/experienced anything like this before?
Thanks
covered in the PFC FAQ
the datalogit and hand controller should not be used at the same time. this is because they share the same bus and bandwidth from the powerfc
that is, each data cycle may be missed by one and the other. so cycle 1 knock of 40 daalogit see's it, but hand controller doesnt, cycle 2 hand controller see's it and datalogti doesnt
its fine to use both to just play around etc
but if you are logging and tuning you should only use at at a time, and not both as it's a shared bus and was never designed for dual devices reading data at the same time
Thanks Paul
It seems to go a bit deeper then that though, when logging individually with both items I'm still getting more Knock on the hand controller then in datalogic. It got looked at yesterday and my tuner said it looks good, plenty of fuel and the timing is not as far as it could be. Datalogit is showing everything is fine, just when the handcontroller is in I get knock at random times. Ive got nothing plugged in at the moment and havent seen my engine light flash to indicate high knock levels since.
I'm thinking the hand controller might just be a bit funny. The main points it seems to be knocking are low revs high load (eg Foot flat to the floor in 5th gear going between 60kmh-80kmh etc)
Sorry I was a bit vague in my last post
Just let me know if you've experienced this before. Im going to do a bit more logging individually with hand controller only and datalogit only when I get the time
Thanks
is your tuner logging basic or advanced knock? should be similar but can be slightly different. how many different things is he logging at once?
also, how high are the readings your getting on the h/c?
    • Thanks Pac!   I will reach out to them!
    • Yes, but 2 things of the top of my head, 1. Legalities of nitrous on a street car. 2. No chop chop. I fully understand that there's much cheaper ways to make power, and whilst a wet 50 shot is fairly cheap to install, bottle fills are expensive, and bottles always need to be refilled, and nitrous also has its own inherent issues with reliability, and tuning, from my experience of others using nitrous, it doesn't take alot to lunch a engine real quick if something goes slightly wrong when spraying, if I wanted a big chunk of additional powers, a spooly boy would make alot more sense, disregarding the additional engineering, supporting mods and other logistical issues of sticking a spooly boy on a car that came naturally aspirated from factory  In the end I'm not racing for sheep stations, and I don't really care if people make more power, or are faster than me, or spend less, or more than me, the only thing the car needs to do is drive around and make me smile, which it is doing now Really, I just want a shiny new intake to look at when I'm cleaning the engine bay, and of course, some more induction doorts, and maybe even that 5kw for that elusive 200hp cherry on top that I might get If the FAB9 intake plenum, TB and air filter box thing doesn't eventuate for whatever reason, Plasmaman do one, not as fancy looking, and a fair chunk of more cash is required when including the TB and other bits and pieces that are required to install it, but, it is another option that is available to me if FAB9 one does fall down (but I really, really.....really, want the FAB9 one though) TL;DR. You want what you want
    • Been so long since I have been here,seeing SDU is dead. I had that problem on my gtr in 2006 but luckily there was no engine damage,it was inspected by Hytech Engines,race bearings and extended crank collar put in and that was about it. Hopefully yours is sorted now.
    • Would it not be cheaper to just spray nitrous?
