well the H/C gives strange readings, sometimes I'll be at say 1/2 throttle doing 100kmh accelerating to overtake someone and it will knock its head off, Ive had readings up around 160, but more commonly get between 60 and 90. But theres no audible knock from the car ever, It runs smooth and perfect.
Pretty sure we were logging advanced Knock on the datalogit and it was hitting 30 at the most when we were doing that. And that was doing some high load runs in 4th, a full run through 2nd gear and some playing around in 5th where id noticed some knock levels. Nothing to be worried about in datalogit but the HC quite often logs worrying numbers.
He seems to think the tune is fine and the HC might be funky, so I've decided to take it out for now, thinking about borrowing another HC and seeing if it makes a difference.
Hope that info will give you a basic idea of whats going on :D
EDIT: Sorry there was 2 cells that were registering around 44 Knock (advanced Knock) on datalogit which were touched up, now register below 30, but they were the largest readings that I can remember
Edited by 89CAL
johnoo is bang on
but also
when you are viewing hand controller knock is it on the street or dyno
and likewise with datalogit, is on the street or dyno
i found everytime cars knock differently on street with the owner driving them vs the dyno and dyno operator
i think this is because the owner drives it differently to the dyno simulator and also the owner usually changes gears differently slightly etc
so are they both in the same identical conditions??
Yeah same conditions. I've observed the HC readings since it got tuned an know roughly the points it knocks. So we plugged the datalogit in and did the same sort of runs. Slowly accelerating from 60-80 in 5th usually seems to do it so we tried that as well as doing some 4th gear runs and 2nd gear runs throughout most of the rev range. Even went up some hills while doing 1 or 2 high load runs.
The car runs great and like i said I've never heard it detonate even when I've got really high readings above 100. I'd like to do some more logging with datalogit on the weeked just to see if there's any knock to double check. But ATM I'm thinking either HC has issues or maybe my knock sensors are faulty.
But to answer your original question yes both occasions were on the street lol
What do you think? Youre the best person to ask I figure, yur knowledge of the power FC far exceeds mine :D
EDIT: sorry forgot to say. I usually log speed, revs, knock and wtr temp on the HC. when I play around next time I'll try just logging knock
Edited by 89CAL
yes try just logging one thing instead of lots of things
there is no logical reason hand controller would see knock differently to datalogit
and make sure you arent using both at the same time as its a shared bus
Hoping for some help on this one. I have an AP engineering Power FC for my R32 with RB20DET. I've had the Power FC for approximately 12 months and haven't had any trouble with it, until today. Upon driving on very light throttle the exhaust overheating light flashed once for about 1 second. So i thought i would check the peak values on the hand controller (i keep it out of site) and i discovered that the hand controller is stuck on the Apexi logo? The last time i checked it, a track day last week, it was working fine. Now it obviously still has it's tune because the car is running fine even with the Z32 AFM, 555cc Nismo injectors etc. Has anyone heard of this happening, is it possible that my hand controller is fried?
Thanks Paul. I'll do some more logging and see how i go
to properly test it make sure you log only advanced with the datalogit (no basic, aux, sensors or any of that stuff) without the hand controller plugged in.
Fixed. The plug for the hand controller was loose and only just making contact. I didn't realise the computer had been moved from its original position since having the roll cage and side intrusion bars installed. The unit now resides under the carpet on the passenger side and after taking a passenger on the weekend (a rarity) it must have been knocked loose.
  • 3 weeks later...
  • 4 weeks later...
hi guys i am encountering a problem. i have a rb20det in a 1983 mitsubishi galant (sigma) and i recently changed the stock ecu to the power fc djetro. it was tuned and everything but i am realizing the the rev limit is not saving when the car is switched off . i did a test and set it to 4000rpm on the hand held controller switched off the car, started back and it set back to 8000rpm. any help would be appreciated i went through this post and also through http://paulr33.com/. but i still cant find an answer. i looked at all the wiring diagrams i could google and everything looks like it is wired correct . next question will the tune as well be erased or it is it just the rev limiter . thanks in advance
the powerfc updates the tune in real time, and then when you key off, commits the changes to NVRAM
in the powerfc FAQ there is a section on this exact issue, search in the FAQ for "ECCS" and youll find a section on how to correctly set it up
on your car, as youve done an engine swap, the ECU isn't given enough time when you power the key off, so it doesnt get enough time to save to NVRAM, thus any change is blown away
the ECCS diagram shows you how it should be setup and how it needs to be wired in
Hey man,
Just reading over all the FAQ and so forth.
It says that the AP Engineering Power FC is not sold new anymore and I have an R32 GTS-T...
Is secondhand the only option for me?
James
Hey man,
James
yep 2nd hand is your only option
you can buy a 2nd hand PFC rb20det version and the new version EL hand controller however
i would do that if you find one without a hand controller
I think I'm gonna go Haltech Platinum Pro...aussie made...aussie tough...newer...more advanced etc etc
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
