the faq covers "hung on apexi logo"
15volts its too high, dead fuse for regulator circuit (i had this problem in my 33) theres a fuse in the boot for the regulator signal, its dead or removed, check it. engine light will only be on if you use boost kit without actually having the boost kit, it sounds like it may have done factory reset. if so turn off the boost kit under ETC, FUNCTION SELECT.
are you in melbourne ?
and unfortunately i cant do much with it as i dont have a commander for this. There are 2 types of hand controllers and it seems i can only get my hand on the wrong one!! thats why the apexi logo hangs. Also found out that a couple of people who have had to jump start or had dead flat batteries with power fc's have lost their maps in the process.... I fear that this will be my fate too. Flat broke so if that is the case the ol 33 wont be on the road for quite some time!! lol Getting alternator back tonight from a reco (needed it bad!!) so will put that back on and let you know what she's up to from there!!
you wont loose the map if your battery is flat or if you jump start it. the tune is saved in nvram. i fried my powerfc (blew it up by shorting the wrong wires) and i had it repaird by a friend at work and my tune was still present.
i have datalogit so i can access your powerfc but i can't tune it for you (no dyno). dr drift in melbourne has access to datalogit (and dyno) and he can tune it for you no problems. it just may take longer with no hand controller
give him a call
added djetro info for other djetro models (evo lancer, s15 200sx, gtr)
added wideband tuning
added full menu options for all powerfcs
added idle hunt / idle surge fix
added FUNCTION on / off japanese character key
updated some of the self tuning for ignition timing areas
updated idle reset procedure
updated info for apexi powerfc pro discontinued
  • 3 weeks later...
an important update is coming soon
re: starting issues with 414-AN012 (was a once off problem, not a bug)
active lsd on ecr33 FIX
for those active lsd customers check out http://www.skylinesaustralia.com/forums/in...pic=107656&st=0
Ok, got regualtor fixed, reco'd the alternator only to read your post about fuse, and guess what.... you were DEAD RIGHT!!!! Replaced fuse, all is good, still have the engine problem though. Seems ok under load, off load (ie: cruising at set speeds) it misses and farts at a certain interval, like every 3 seconds, it farts for 1 second, then fine for 3 seconds, then farts for a second and so forth. Finally got hold of a hand controller thats for an r33, and ......NOTHING! Apexi logo hangs, but i did find that if i hold up button whilst turning ignition key on it goes to a screen that just says "FN" ????
Think i may have fried some or all of the power fc? Googled the shit outta "power fc FN" etc only to come up with didly squat...nothin!!!! Help me please!! lol So far you've been spot on the money! If need be i'll express post it to you and you may be able to fix it!! lol, the problem i have is its supposed to be in a wedding march 18th!!!! not looking too good!!
i have tried looking into all of that, what i've found is this, which is just what "i think may be right".
That for r33 skylines there are in fact 2 power fc's around for them, one is serial ECR33 XXXXXX and the other is RB25 XXXXXX, the ecr33 one uses the hand controller FCC3 XXXXXXX and it looks like the RB25 (my one) uses a controller FCC NT XXXXXX
I cannot see anything on the controllers or power fc units stating numbers anywhere near 414 N001 or X001. Mine says PFC RB25 -9705 - 0013 on the unit and the hand controller says FCC3-020-10512
Man, im glad you've got the brains to figure out this stuff!! That bloody FAQ you've done is a credit to ya and it would have taken a LONG LONG time to get to the stage its at!!
so the pink & black soleniod wiring is wired into the factory soleniod loom green & blue/white wires ? is this correct ?
is the z32 afm from the vg30 engine, so what voltage value do i use ?
Also ive got 555cc nismo injectors, what value do i need to use in the injector value menu ?
Hi Paul,
Just a though here, don't shoot me down in flames :laugh:
How about you add a section on doing full power ignition tuning? As long as you have a good set of knock headphones, it isnt too hard. I know of a few cars that have been 'street tuned' this way with a wideband O2 meter as well.
Cheers,
Matt
whilst i wouldnt mind myself
its basically a case of up timing and watch for knock
i can put lots of stress on the car
and also its a big change of the tuner "amatuer" to really bork the engine.
i would rather a pro do that part if it makes sense
very interesting read, thanks for all the info, i have tried some of it, but im still not confident im doing the right things. Anyone in Sydney know a cheap place to tune the power fc properly ?
  • 4 weeks later...
im assuming rb20 powerfc would suit which is an ap engineering model.
the 4wd controller system is performed by a seperate computer to the ecu. you may find the tps signals and rpm have to be run manually as the rb20 ap engineer wont expect to have an attessa ecu piggyback-ing off it
  • 3 weeks later...
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....馃ぃ) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
