ok its very easy you need to go settings the RPM you will see i think the top rpm setting is your idle i will try and get pictures and stuff
hey i think i see what your talking about, but in there it says following:
rev limit-6900
F/C A/C 1200
F/C A/C 1300
IDLE A/C 650
IDLE A/C 700
so the idle in neutral rises every time i start or put the clutch in after crusing etc, ( same as an auto when you shift from D into N) to around 1300rpm then settles after bout 10sec to be 1000rpm..eg at traffic lights or just starting it hot , starting it cold it stays shoots to 1400rpm then settles to 1300 til it warms up a bit...
its the hot idle i want to return to 800 or 900, to quieten it down, cause on a fast idle its very loud, booming noise, embarrassing lol when your sitting at the traffic lights etc..
Thanks Paul I was trying to find that
Sliver its a simulate pfc you can use it like a real one
ah ok, i see now, thats pretty good
so this is the problem then, mine is set to idle at the correct idle but its actually idling at 1000rpm, why do you think thats happening?
how long do you drive it, i have to drive mine about 5-10 mins before its warm enough to drop its cold idle
could be a dirty AAC Valve >>DIY to clean it<<
might not be set on the other settings properly
set it up just like the picture if you want a factory rev limit leave that part alone
http://www.paulr33.com/powerfc-emulator/menu_1_2_10_1.html
http://www.paulr33.c...u_1_2_10_1.html
ahh the revs come down after bout 5mins, from say 1300 to bout a 1000rpm,
i noticed the fast idle after it was tuned, dont think i had this high idle with the factory computer, thats why i was wondering bout the pwr fc settings, ill go clean the AAC valve tomorrow to rule it out though..
what causes the revs to fly up to 1300 initially though? can that be changed?
eg, driving along, pull up at the traffic lights and clutch in, revs hold on 1300rpm for 5-10sec then die down to 1000rpm, not really necessary for it to do that
it feel like when using an automatic and changing back to neutral..when stood still
not sure certainly sounds weird
my fast idle is only about 1100rpm
yeah it all seems a bit fast, even the cold start, flys flys up to 1500rpm, varies a little though, somtimes lower, maybe those two idling setting of 1300 and 1200 that are on there should be altered to 1000rpm.
hi all
i have a power fc for a 34 gtr, i am looking to hook up a boost controller unit to this...
i believe there is a special loom/spec one for the rb26 (3 pin plug)
i have found one that looks to be minus a few bits and wanted to double check with some one who may have used one b4.
it will need
- 1x solenoid (with hose fitting)
-1x map sensor
-hose and fittings etc etc
now is there 1 or 2 wiring looms?
1 from the power fc unit to the map sensor, and the soleniode hooks into the stock loom.
or is there ment to be 2 wiring looms?
pics on google suggest both :S this is where im LOST!
also what was the serial numbers of the power fc units that had the glitch of ignition?
i recal a -8? -08 or somthing...
cheers boys
there is 1 loom but 2 versions of it
there is the 3 pin version and 5 pin version
depending on what powerfc model you have, and which socket you have on the side determines which version to get
on BNR34 from memory it is the 3 pin version
the 3 pin version is actually 3 pins for the map sensor (power, ground and signal)
the other pin is on the main ECU loom and it's the boost solenoid / wastegate solenoid wire
this wire runs to the factory solenoid and you simply re-use that and it re-mates to the AVC-R solneoid (power, ground)
the 5 pin kit is used where the car does not have a factory controlled solenoid
so the 5 pins is 3 for map sensor, 2 for solenoid
Heya i know this has already been discussed but just wondering how much work is in changing a 32 gtr power fc to a 32 gtst if possible? and is it worth it compared to a nistune?
Any help is great thanks :)
how to wire BNR32 PFC into R32 GTST is covered in the PFC FAQ and workshops can even do it for you
read the info or get a workshop to do it for you or buy a legit AP engineering HR32 powerfc
  • 1 month later...
whats the deal with the handcontrollers? i have one that came with a pfc i bought that doesnt work but the handcontroller works fine except when ive tried plugging it into a couple other pfc's (one was the pro one thats in my car now and the other was a regular 33 gtr one) it wont go past the apexi logo. the serial of the pfc it came with is GTR33L 020-1825 and the controller is FCC3 020-18807. im trying to sell it and its a bit hard when i cant get it to work when someone comes round to take it.
cheers.
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
