My car is in the shop at the moment and the guys are unable to get the ecu to communicate withe PC. Not 100% sure on the issue but will find out more tomorrow.
They are waiting on a reply from fc datalogit but from what I have read I dont think I should hold my breath.
How did you go with this?
I put my new one in today and the version 7 power fc wont communicate, but I just had to send a scan (FC-Edit did this automatically) in an email to the guys at fc-datalogit and am just awaiting a reply. But if you have answers before they get back to me it will be great so I can put my tune into the new Power FC
Can't edit so I will do another post.
FYI Paul, if you want to put it in the FAQ, for a version 7.00 Power FC for RB25DET (AKA the new release ones) you need FC-Edit Version 2.130k for the ECU to talk to FC Edit :)
  • 6 months later...
  • 1 month later...
Hi,
Will you update the FAQ on apexi's release of new PFC's with d-jethro for RB25DET ECR33 ? The part number is 4E14BN32 and fits series 1&2. Finally gts-t owners can get rid of the AFM unit and still keep the NVCS system(since RB26DET pfc d-jethro conversions lost that feature).
  • 10 months later...
Hi,
hi sorry for the mega late reply. i can but i need someone who has this model in their car. the main things i am after is ETC, VERSION - SENSOR SW CHECK and also SETTING, AIRFLOW (or SENSOR)
some screen shots will help for the FAQ as these are the main content items to include. so if someone has this model working with photos i can put it up
  • 3 weeks later...
What are the reasons that a power fc would make the engine light flash.
Most common will be knock....
May also flash due to injectors maxing out etc etc
Is covered in full in the Apexi FAQ.... Many many topics on this.
Helo. Quick question. If I have a q45afm and power fc. How come my car runs a lot nicer when I select r33afm in settings,Apart from the lite popping at idle. When I select q45 it runs like shit, there's too much fuel everywhere idle and boost. The only plus side is it has a lot smoother idle although richer 11.0.
All this is the same if I load a previous owners tune or if I load a sample map or even if I data init.
in case this helps others,
Hey mate thanks so much for all the guides you provide they are invaluable. i am trying to figure out why the second hand pfc i have is getting stuck on the apexi splash screen.
the ecu says FC1 r33 inside the shell and PFC rb26 9811-0011 on the outside of the shell.
Does this ECU need the FCC NT hand controller?
the one i was sent is FCC3 010-00722
are there any other reasons it would freeze on the apexi logo if these are indeed compatible.
regards
yes you need either FCC NT or FCC4
if you goto nengun.com you can buy the EL hand controller brand new as it works on all PFC versions (it's FCC4)
FCC2/FCC3 are hard set for the newer PFC's
that is, PFCs with RB26XXXXXX as the serial are older style PFCS and PFCS with serial ECR33-XXXXXX (or BCNR33-XXXXX) are newer style PFCs
same functionality, same features, different firmware.
the PFCS that are RB26XXXXXX were sold seperately with hand controller where as PFCs with BCNR33-XXXXXX (for example) were sold as PFC and hand controller bundle
basically apexi made original PFCS to suit the engine then the "newer style" were sold to suit CHASSIS instead of engine code
so
PFC RB26-XXXXXXX (old, needs FCC NT or FCC4)
to
PFC BNR34-XXXXXXXX (new, needs FCC3 or FCC4)
  • 3 months later...
Hey Guys, Just switched to larger injectors.
Needed to go in and update the latency and cc's. I dont have a commander.
Friend dropped by with his Commander and Datalogit. Commander is universal.
We can not get either one of them to connect to my ecu.
Power to Pin 58, 12v.
Motor is an RB25 S2 in it.
Any ideas?
Car runs perfectly fine, just wont connect to either piece.
  • 3 weeks later...
    • HUMVEE are fine in big open areas, but they are problematic on the street and tight areas As for reliability, some of the  US Army guys I have chatted with have said that when they were working they were fine, but, the do spend alot of time in workshops for multiple reasons, admittedly, they did get a hard time by the boys and girls who drove them I would definitely put them in the "buyer beware" category  They do look tough as nails though
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
