I've asked about it from a few tuners and all have reported to just leave it and dont change it
Ive connected a Wideband A/F guage and if i give it medium throttle, it richens up to say high 11's and then goes to mid to high 12's once your on the throttle and the accelearting enrichment has gone. This is only on medium throttle with very little boost. I played with it and now im in the 12's and ive noticed an improvement in throttle response. '
I'll do some more testing and leet you know how i go.
expanded on bad idle problems (how to correctbad idle / cranking / starting problem)
added evo8 support (harness part #)
added eccs wiring howto (bugfix to correct memory save problem)
added dialing in larger injectors
added authors notes
Has anyone tried playing with the Accelerating Enrichment program on the Power FC?
Here's some info I posted elsewhere in a Datalogit context.
The "Inj vs Accel TPS1" area of the 'settings 2' tab affects the
linearity of the Accelerate Injector settings. You don't want 100%
of 'accelerator pump' settings to kick in when you just apply, say,
a 25% change in throttle position. Nor do you necessarily want 25%
of the extra fuel. The 'input' field is throttle position in units
out of 256. (128 = 50% throttle) The 'setting' field is the fraction
of Accelerate Injector setting out of 256 that will be applied give
the partial throttle increase. There are three 'linearity'
adjustment points, but be aware that there are two more fixed ones.
(0,0 and 256,256)
I've found that I need to set the first 'Input' box to a pretty low
TP number (5/256) and give it a fair shot of fuel (175/256) to avoid
leaning out under modest throttle increases. The PFC linearly
interpolates between these points, so for throttle positions between
the linearity adjustment points, you'll get a smooth transition.
Hope this helps,
Dan
corrected powerfc dongle information
added INJ guesstimation for lambda
added airflow precentage correction map scaling
added updated datalogit version
added missing eccs image
hey i just went through and wrote every single bit of inforamtion down from my pfc, the ign and inj maps and other thibngs like the water temp screens etc etc..... took me a bit, am i right to reset the pfc and reload those valuse what do i need to be careful of (its just when they tuner put my pfc in he didnt do the idle learn thing with the a/c etc so my idle hunts)
  • 3 weeks later...
added repairing powerfc notes
expanded on airtemp support
added knocking explantion with likely causes
added advanced knock debug
added datalogit AFR plot
added rb20 vs rb25 pinouts
added r33 sensor SW check page
added R32 sensor SW Check page
expaned on hybrid version support
- differences between RB20 and RB25 looms
- support matrix for features
There's an error in the FAQ. The R33 BCK is 3 pin for the MAP sensor harness to PFC, and the solenoid harness plugs straight into the harness for the oem solenoid.
You can control boost using the oem solenoid with the BCK MAP sensor (I tried this) but the control is awful, as you'd expect from a 2 port solenoid.
Hey guys,
Great thread!
I have a question.
On the old Nissan ECU, starting the engine was no problem at all. Sounded like 2 cranks and she lit up every time.
With the Power FC after, a full tune by the Hitman and the 30 min warm up idle setting, it takes about 8-10 cranks to start.
It starts every time, don't get me wrong.
Just thought it strange the standard Nissan did it better than the Power FC
Any settings i could be looking at?
Thanks
Birnie
Chris (png_gozilla) please see here ->
http://www.skylinesaustralia.com/forums/in...howtopic=127769
I moved your post so youll get a better answer in that section
hi, I've actually bought a used FC that has been in a car and tuned to 230rwkw with stock everything except cat back 3" exhaust. I have a full engine rebuild with ARC air box. full 3" to 3.5" exhaust will it be ok to plug it straight up or too much of a risk???
Also, i have an AVCR installed but never turned on, can i just use that boost kit and harness for the FC??? Or get it tuned straight away???
Just wanna be sure before i do anything??
Cheers in advance..
Edited by ib6ub9
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
