  • 3 weeks later...
Awesome thread Paul. Well done.
More info than i'll ever need.
Just a thought for anyone with a blown Power FC, that is having probs getting it fixed:
The boys down at 'Access Autoworks' in Vermont, Melbourne (used to be in conjuction with 'Hypertech', who now no longer exist) may be able to help out. Only reason I say this is because i have an ECR33 Power FC currently on its way to Japan to be fixed up. It was blown when trying to install into my R32 GTS-T with RB25 transplant (Jap conversion) and wiring was up the creek.
So if you cant get one fixed, rather than throwing it out, or buying new one, give them a try.
very nice write up. very very handy.
when installing.. do u recommend warming the car up then installing the PFC or just bolting it in and warming it up with the PFC? i ask as does it need to learn its own cold start?
im about to get a 1995 R33 GTST i think they have a Series 2 engine as its a Series 1.5 so is ther a Different PFC for the series 1 and 2?
the car comes with one not installed is ther a way to verify it is the right PFC for the car?
thanks in advanced.
mark.
there is no difference between series 1, 1.5 and series 2 for PFC
33 gtst model suits all. you should warm the car, the install the powerfc and perform the self idle lean procedure (covered in the FAQ)
I plan to install one in my mild modded GTST and run it on base maps for a month or two whilst I save up the cash for a tune. Am I gonna have problems starting it in the mornings and stuff?
I am about to install a 2nd hand PFC... And im not sure if it has a tuned map in it.
If it has a non-stock map will it still perform the self tune setup? is there a way to get it back to base map?
Thanks
thanks paulR33 its a very good read. i read nearly all of it. it doesnt mention to warm car up prior. i just assumed and asked for confirmation.
What type of fuel economy will it be like with the base map? without touching the AFR aswell? just a straight bolt on.?
thanks a bunch
mark.
I have a SAFC installed on a standard R33 GTST ECU.
Is the base map on the PFC exactly the same as the standard ECU?
Would it be a problem if I install the PFC and keep the SAFC in the car until i get it tuned?
Is there a way of copying the settings from the tuned SAFC to the PFC.
Maybe by writing all the details from the SAFC on paper and then input these settings on to the PFC.
I do not realy know or the setting options are almost the same between the SAFC and the PFC.
Thanks in advance
Gijs
thanks a bunch
mark.
fuel economy will be ok ish providing you have a working 02 sensor
Thanks in advance
Gijs
no the stock map on the powerfc is not the same as the stock ecu map
it has a bit more tuning and a little bit leaner afrs probably.
when you get the pfc, remove the safc completely (and sell it).
you should not need to run both, nor is it a good idea to.
the safc is simply correction values for 20 load points, its not a complete map so no, the data is not compatible.
i was tempted to order an rb26 powerfc tonight and wire it up to my rb25 and write up a quick howto so for those looking for powerfcs on their r33 could simply follow the steps using a new rb26 PFC but i have some concerns
1) duplexing the afm input to the 2nd afm pin
2) duplexing the 02 sensor input to the 2nd afm pin (if wanted)
3) altering the injector settings to suit rb25 370cc instead of rb26 440cc (so possibly negative correction or latency??)
4) getting a working VCT setup (friend suggested buddy club device $90)
if anyone is willing or interested to work on some of these it coudl be helpful for all
Hey Paul,
Had my FC in for about 4 months now without missing a beat.
Get the occasional orange light pusle on the engine light for the standrad, reaching max levels warning. (no problem)
Today, for the first time, the engine light has lit up but stayed hard on for about 20 secs.
It happenned when coasting down off the throttle, and on another occasionally when sitting on idle.
Idle was fine, revs were fine, everything seemed as normal.
All temps, oil, all good. No other lights.
Anyone encountered this before?
Maybe a faulty sensor? (i hope)
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
