if the engine check light stays on it means a sensor is out of range, not working or giving incorrect values. when you see it on, look at ETC, SENSOR SW CHECK and look for any sensor names with a black background around its name. this indicates the fault sensor
if you enable the boost kit for enable and dont have the map sensor harness connected the engine check light will be on and BOST under SENSOR SW CHECK will be highlighted, indicating the boost map sensor isnt working or out of scope (ie: its not plugged in)
hey paulR33.
its ok to run the GTST with a PFC. but if ur only commuting will it be economical to run it with the stock ecu. i wont have time or money for a tune. so just wondering. is ther any real world figures. my GTR averages 12-15 p/100kms. what will a base map PFC on a GTST yeild?
thanks again
mark.
thats what i was thinking myself.
just like to say we all apprciate the write up and effort put into this PFC guide. its the best we could find on the net. and thanks for answering somewhat repetitive questions so promptly. your very appreciated mate.
thanks again
mark.
Just installed mine and can I say how much better the base maps over a the standard ECU. Teh car feels so much more reponsive now...shift from 3rd and 2nd and the thing just launches!!!
Now to get a tune........
  • 3 weeks later...
I was wondering if there was a way I could display my oil temp on the PFC. Maybe I could use the Air flow temp function to measure the oil temp via a sandwich plate? Do you know if this is possible Paul?
  • 4 weeks later...
added correct pfc boost kit port mappings (on the solenid)
added photos inside GTR-RB26 PFC
added photos inside APENG-RB20 PFC
added piggbacking the powerfc
added power fc pro launch control
Hi there paul, great job on the thread mate its damn helpful, ive just installed my PFC into my r33 GTST 2 days ago with the assistance of your information, the car feels a tad better than the factory computer, im saving to get a tune, hopefully with in the next couple of weeks
I've noticed on start up one of the two relays which are mounted behind where the computer sits, clicks about 4-5 times as soon as i turn the reds on and the hand controller flashes with the clicks.
It done the same thing the morning after the install while driving with the engine cold turning right out of my street it clicked 4-5 times and i nearly got stuck in the middle of the road, once it warms up it doesnt do it while driving, but will still do it on start up, and the hand controller works fine.
I've plugged the factory computer back in just to check if the clicking still occurs and it doesn't.
I also swapped the clicking relay with 3 other relays and they all done the same
The clicking of the relay really has me stumped i cant think what could cause it, but its definately related to the PFC, something is switching the relay on and off really quick, any help you could give me would be fabulous and appreciated
The car is not heavily modified just a full exhaust, FMIC, cold air intake, 10psi boost and a walbro 500hp fuel pump
The PFC was brand spankers in the box.
Thanx again.
Thanx again.
I could be wrong with this but at least its a quick and simple check to do.
Check all of your fuses below the dash on the drivers side. Don't just check they are all ok, check they are all there. I attached the pic of the english translation of it. I was missing the electrics or engine control one.
Go through the PFC FAQ it has a section on problems with clicking relays
R33_Fusebox_translation.doc
Edited by Fry_33
Just like to say, Great FAQ dude.
Once finding out that the R33 PFC's were being discontinued, i raced out and brought one today, just tuning now. Only paid $1500 so happy with that given the situation.
PS. Anyone looking for one? Maybe contact JJR, i got mine there and there were about 2 more and 1 2nd hand, although the new ones were apparently sold! But still waiting there for pickup
cheers again! :sleep:
fry is correct, i would start there and check what he has mentioned.
i have never heard or seen a PFC click 3 or 4 times before boot up and come online normally.
usually if you have clicking relays its toast and never works. am surprised it works
only thing i can think of is view SENSOR SW CHECK with the car on ACC and see what it does ?
i checked fuses in engine bay, cabin and boot, they are all good and can't find any missing
i assume power to the PFC should be well because the factory computer is A-1
is it faulty? i hope not but i need to sort this out because if it is i need to get it repaired under warantee which sux as its brand spankers and i paid 1500 for the damn thing
ive got it booked for a tune on thursday and i just hope they have seen this problem before and hopefully know how to fix it *fingers crossed*
will do what you said in the morning paul sounds a good idea
thanx for your replies guys :(
thanx for your replies guys :)
Just because the factory computer runs fine doesn't mean the Apexi will. My car with standard ECU was running fine without the fuse I mentioned, the apexi wouldn't work. The standard ECU's tend to be less fussy with some missing signals and weak power.
If all your fuses are there and fine you may need to start looking at your wiring.
Pin 58 (black with white stripe wire near bottom of harness i think) needs to have a good 12V going to it. Just unplug your ECU harness and check this with a multimeter.
While you are at it check pins 50 and 60 (2 black wires on the bottom of harness I think) and make sure they are good earths.
Thats a starting point.
good luck
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
