There are heaps of debates over the filters (pod or panel) and how good they actually
are for your car.
chicane is right - partition it off otherwise you will be sucking in ALOT of hot air coming off
the engine.
The debate is; that some filters have very good air flow but poor filtration, thus getting
dust and particles into your motor, where as other filters have poor air flow but are doing
what they are meant to be doing and that is to FILTER particles and crap. It will depend
on where you live, ie. dusty area, or nice clean area.
Best you can do is keep it oiled, and build a nice solid partition to keep heat and unwanted
crap out. You can buy one for about 150ish or build it yourself, I just recently built one myself and you can stick on hand in the engine bay area, and other in the pod partition area and really notice a difference in temperature after a spirited drive.
K&N, Blitz, Apexi, Unifilters - they wont vary by very much, the most you'll get is an additional or negative few kw
Eug
https://www.sau.com.au/forums/topic/64217-pod-filters/#findComment-1205054
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
