I was thinking about changing over to BP Ultimate from Optimax, and I thought that it was available from Kingston and Phillip... but the BP website doesn't show Ulimate available this side of Sydney. As I'm almost certain that it is available at Marulan, they would mean their web site is stuffed, but I don't really feel up to ringing up all of the BP servos in Canberra.
So - has anyone seen BP Ultimate for sale in Canberra?
https://www.sau.com.au/forums/topic/64238-bp-ultimate-in-canberra/
I only use BP Ultimate (I had to put Optimax in it yesterday as I didnt have enough to make it to a BP - and its hate f#cking me for it already with the knock sensor going crazy!!) and its definately availible from Civic, Kingston, Phillip and Chisholm. Not too sure about northside as I live south :)
I'm quite sure Ultimate is availiable in 2 places in Queanbeyan, one of them is the BP next to the main drag, and the other (I'm definite on this one) is the little BP on...Uriarra Road (I believe it's called).
So that makes six? places?
Urriarra Road Queanbeyan
Kings Highway Queanbeyan
Chisholm Shops
Melrose Drive Phillip
Canberra Avenue Kingston
Cooyong/Lonsdale Street Braddon
there has to be some northside?
yep i filled up on it a qbn on tuesday night, i never thought there was any diff beetween the 2 (optimax and ultimate) but after puttin a tank of optimax back in the car a few months ago, it felt like someone had taken my turbo off untill i put ultimate back in.
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
