After reading a few posts about the coil pack issues i was wondering,
1. How much for new set of coils
2. Where can we get them from
3. Watt brand (Spitfires/Genuine nissan ?)
Also O2 sensor & crank angle sensor....how much and where can we get it from?
I got my car dyno yesterday at Jem performance at Moorebank NSW
but I did the following before the dyno,
1. New fuel filter(coopers brand)
2. New BCP7E NGK Spark plugs.....(no adjustment on gap.. kept standard gap)
3. Reset the ECU
It was dyno at 134 kw. A few adjustments and i got 145kw safely.
Yes my car has got a pingin issue and missfire.
I will try the following now;
1. Clean the injectors out (my car has done 101,000 km now)
2. Seal the coil packs (with either Araldite or that dialetic grease)
3. Change 02 sensor
4. Change crank angle sensor (? not sure about this one yet)
I will do each in stages to c if there is any change between these items do.
maybe we can hopefully isolate something.
Have i left anything out?
What do u guys think?
I've been searching for O2 sensors too, and from these threads, lots of people have found that EL ford falcon sensors are a swap over, albeit with a bit of wiring. They range from $80-$120 from places like repco & autobarn. Aparently the wiring has a diff harness/clip, so you need to cut it and rewire. Seems pretty simple. This is what i'm doing later this week.
Hope that helps.
Looks like you have covered the common stuff.
They are a cam angle sensor also, not a crank angle sensor. Not that anyone gives a crap, but sometimes helps when ordering parts.
What boost level VS timing are you running?
What mods do you have?
ok...... GTR Killer thanks. Thinkin of VL's too much.
I started on my Injectors yesterday. I took the whole Fuel rail out and sent it in with the injectors in it to be cleaned.
I found that in the manifold...the last 3 sections inside the manifold are quiete darker in oil.
I am talking about the last 3 manifold sections closest to the fire wall.
The first 3 are clean as.
I am thinkin o gettin the head ported and polished a little ...while i have the stuff off.
Not sure yet what to do.
With that info I would have to definately recommend a head service which you will get with a port job anyway. The valves have to come out to do the porting so they will re-seat them and replace the stem seals. You will most probably find the nature of your problem once the head is off. Make sure you check your pistons for bore travel just to be on the safe side and check them for pitting or any unusual marks. Make sure you find out what's causing the darkness before you go ahead with the port job. Also make sure they do a full check on the head before proceeding. I know of a couple of places who would just start chopping without checking.
Another thing about porting, on this vehicle it is not advised to extend the head VS manifold area. This, I have been told, is already quite large compared to the capacity of the head. Depending on how far you wanna go with it. Sure, if you have the turbo to match it, then open her right up, but be prepared to open your wallet at the petrol station. If you are going to open this area, make sure you match port the manifold to suit it otherwise your efforts are wasted. Most of your power gains will be made from cleaning up the bowl area below the valve. Do not underestimate such minimal work, you will be surprised at the results.
Polishing is a bad idea....good in the 80's but reasearch tells us that pollishing the heads and manifold is actually bad for performance. You will lose horsepower with a polish.
  • 1 year later...
There is a huge thread on O2 sensors stickied at the top of this section.
Get N15 pulsar plug, $90 from motortraders (trade price) and comes with plug. Plugs straight in, no fixing wires :/
I just got one and definitely does fit
Edited by salad
  • 3 years later...
don't see the point of owning 2 cars as the missus and i both work at the same spot (at my business), and her car is fast enough (will beat natro skylines, lol), and is cheap to run, and tows my tinny well enough, so no point paying $1000 in rego and insurance a year for a lawn ornament.
oh and the bicycles comment was based on the fact i own a bike shop.
what are these 2 cars you speak of
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
