After reading a few posts about the coil pack issues i was wondering,
1. How much for new set of coils
2. Where can we get them from
3. Watt brand (Spitfires/Genuine nissan ?)
Also O2 sensor & crank angle sensor....how much and where can we get it from?
I got my car dyno yesterday at Jem performance at Moorebank NSW
but I did the following before the dyno,
1. New fuel filter(coopers brand)
2. New BCP7E NGK Spark plugs.....(no adjustment on gap.. kept standard gap)
3. Reset the ECU
It was dyno at 134 kw. A few adjustments and i got 145kw safely.
Yes my car has got a pingin issue and missfire.
I will try the following now;
1. Clean the injectors out (my car has done 101,000 km now)
2. Seal the coil packs (with either Araldite or that dialetic grease)
3. Change 02 sensor
4. Change crank angle sensor (? not sure about this one yet)
I will do each in stages to c if there is any change between these items do.
maybe we can hopefully isolate something.
Have i left anything out?
What do u guys think?
I've been searching for O2 sensors too, and from these threads, lots of people have found that EL ford falcon sensors are a swap over, albeit with a bit of wiring. They range from $80-$120 from places like repco & autobarn. Aparently the wiring has a diff harness/clip, so you need to cut it and rewire. Seems pretty simple. This is what i'm doing later this week.
Hope that helps.
Looks like you have covered the common stuff.
They are a cam angle sensor also, not a crank angle sensor. Not that anyone gives a crap, but sometimes helps when ordering parts.
What boost level VS timing are you running?
What mods do you have?
ok...... GTR Killer thanks. Thinkin of VL's too much.
I started on my Injectors yesterday. I took the whole Fuel rail out and sent it in with the injectors in it to be cleaned.
I found that in the manifold...the last 3 sections inside the manifold are quiete darker in oil.
I am talking about the last 3 manifold sections closest to the fire wall.
The first 3 are clean as.
I am thinkin o gettin the head ported and polished a little ...while i have the stuff off.
Not sure yet what to do.
With that info I would have to definately recommend a head service which you will get with a port job anyway. The valves have to come out to do the porting so they will re-seat them and replace the stem seals. You will most probably find the nature of your problem once the head is off. Make sure you check your pistons for bore travel just to be on the safe side and check them for pitting or any unusual marks. Make sure you find out what's causing the darkness before you go ahead with the port job. Also make sure they do a full check on the head before proceeding. I know of a couple of places who would just start chopping without checking.
Another thing about porting, on this vehicle it is not advised to extend the head VS manifold area. This, I have been told, is already quite large compared to the capacity of the head. Depending on how far you wanna go with it. Sure, if you have the turbo to match it, then open her right up, but be prepared to open your wallet at the petrol station. If you are going to open this area, make sure you match port the manifold to suit it otherwise your efforts are wasted. Most of your power gains will be made from cleaning up the bowl area below the valve. Do not underestimate such minimal work, you will be surprised at the results.
Polishing is a bad idea....good in the 80's but reasearch tells us that pollishing the heads and manifold is actually bad for performance. You will lose horsepower with a polish.
  • 1 year later...
There is a huge thread on O2 sensors stickied at the top of this section.
Get N15 pulsar plug, $90 from motortraders (trade price) and comes with plug. Plugs straight in, no fixing wires :/
I just got one and definitely does fit
Edited by salad
  • 3 years later...
don't see the point of owning 2 cars as the missus and i both work at the same spot (at my business), and her car is fast enough (will beat natro skylines, lol), and is cheap to run, and tows my tinny well enough, so no point paying $1000 in rego and insurance a year for a lawn ornament.
oh and the bicycles comment was based on the fact i own a bike shop.
what are these 2 cars you speak of
    • It might be fine. I was just saying that I wouldn't trust it without testing it.
    • Traction wasn't bad, l couldn't give it everything off the line but was able to go WOT about half a second after rolling - good for NZ drag strips.   Like one run I did a 1.96 60ft and pretty sure I was on for a 12.4 but lifted early as I was on a 12.5 dial in, and still won haha
    • Nice one! I was going to take mine down to SMSP drags one Weds night. I'd love to compare it with my GTR which did a 12.3. The bum-dyno in the 335i says its quicker.   How was the traction @Lithium?
    • AFAIK I've seen other people recommend using the back of the balance tube as well. Andre Simon from HPA at least. I can't imagine it being that far off from ideal even if it was only used to drive a boost gauge from the factory.
    • Hi All, New member here, I've joined to help my son with an issue that is truly doing our heads in. I'll start with a bit of an overview. Chris carried out some modifications to the engine to try and extract just a little extra power out of the motor and make it a bit more efficient. Previous to this work, the car already had an upgraded exhaust, increased boost up to 14psi, modified standard turbo to metal impellers and slightly oversized, upgraded fuel pump, been dyno-tuned at JEM, and some other bits n bobs like coil packs etc. Before the current mods it was making 236rwkw at 14psi but after the new mods it now makes 209rwkw at 14psi. The work he carried out is as follows, timing belt service, water pump replacement, return to sump radium catch can, had oem head rebuilt and machined 0.2mm, fitted Athena cut ring head gasket 1.2mm thick, arp 2000 head studs, added rear prp head drain, added an external wastegate 40mm turbosmart welded off the stock manifold and plumbed back into a 3in dump. The car has been on the dyno and apparently the ignition is working, fuel flow and fuel pressure is fine, injectors are fine, spark plugs are working fine, Maf is working, O2 sensor is working, TPs sensor is working, VCT is working, CAS is working, boost leak test showed no boost leaks, compression test first crank cold 135psi and got to 150psi across all cylinders once cranking, timing is confirmed at tdc with a dial gauge and the cam dots line up, no blockages in intercoolerm throttle body or pre-turbo intake, no blockages in exhaust, cat conveter or down pipe, turbo looks fine and spins and wastegate looks fine and is new. Soz for all the detail but after all this, it has been in 3 times for dyno and each time comes back stating it's not going to make power. After the first (or second, can't remember now) trip to dyno we did find the timing out by one tooth and this improved things, but it is still well down. Does anyone have any ideas?  Any replies much appreciated as we're just not sure of which direction to take this. Regards Rob (Chris's Dad).
