HI ALL
I HAVE A NEW, NEVER USED WOLF 3D VERSION 4 FOR SALE.
IT IS TO FIT AN R32 OR R33, PLUG STRAIGHT IN.
IT INCLUDES THE HAND CONTROLLER WHICH YOU CAN NORMALY BUY SEPERATELY.
IM AFTER $1000 FOR IT, AS IT IS STILL NEW. THIS PRICE INCLUDES DELIVERY TO ANYWHERE IN AUSTRALIA.
THE VERSION 4 GIVES YOU CONTROL OVER BOOST LEVELS AS WELL.
VISIT http://www.wolfems.com.au/home FOR MORE INFO ON THIS GREAT ECU. PRICES FOR NEW ONES INCLUDING HAND CONTROLLER START AT $1595.
IF YOU ARE INTERESTED I HAVE PICTURES OF IT AND I CAN EMAIL THEM TO YOU.
CONTACT ME ON HERE, OR ON MY EMAIL AT : [email protected]
THANKS !
:rave:
Please ignore the negative trader rating... it was left by a time waster, who i posted the item to C.O.D. and he failed to pay for it, costing me return postage also.
I lef thim some negative feedback and he responded by leaving me some?????
idiot.
said in the feedback (if you read it) that i was childish for asking him to pay for it, when he agreed to.....
thanks.. Matt.
ill give u 800 bucks for it , only if u send it to me first and ill wire the money same day i get it :D
haha... cash on delivery i dont mind doing.. at least that way I'll get the money for it !!
800 is a bit low considering the hand controller comes with it.
hi there... i just wanna know,.what exactly does wolf 3d support ? i mean compare to the power FC..? any idea ? coz i've been looking around for an aftermarket ecu..and so far apexi is the way to go...but i am interested with the wolf 3d..could you give more info ?
www.wolfems.com has most of the info.
this system controls the same variables as the power FC and the power gains are the same.
this one is a bit cheaper and has a lifetime warranty. controls boost fuel, air, ignition, timing, blah blah, the lot.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
