JDM Work Wheels CR Kai - from $1400.00 latest design
Hi people,
If anyone is interested in getting super cool Work Wheels for their baby, this is the time to do so!
Latest from Japan is the Work Wheels CR Kai,
They are the big thing now in Japan.
Closing date to pre-order : 25 Feb 05
To arrive : End of April 05
Deposit needed: $400.00
Delivery (optional): $80.00 anywhere within Australia.
Color: Bronze, Gunmetal and White.
Prices as follows (inc.of GST and Tax)
15 x 5.5JJ - $350.00
15 x 7.0JJ - $375.00
16 x 7.0JJ - $412.50
17 x 7.0JJ - $450.00
17 x 8.0JJ - $475.00
17 x 9.0JJ - $487.50
18 x 7.5JJ - $512.50
18 x 8.5JJ - $537.50
18 x 9.5JJ - $562.50
Price is per each wheel
This is the recommended offset by WORK
A ROUGH GUIDE ON THE WEIGHT ON CR KAI WEIGHT
(this is an estimate only)
Size Offset Bolt Pattern Weight*
15x7.0 44 4-100 15 lbs (6.8kg)
16x7.0 44 4-100 17 lbs (7.7kg)
17x7.0 42, 47 4-100; 5-100; 5-114.3 19 lbs (8.6kg)
17x8.0 47 5-100; 5-114.3 20 lbs (9kg)
18x7.5 42 4-100; 5-100; 5-114.3 22 lbs (10kg)
18x8.5 30, 37 5-114.3 23 lbs (10.4kg)
18X9.5 30, 38 5-114.3 25 lbs (11.3kg)
Work Meister S1-2P
17 x 7.0JJ - $3,350.00
17 x 8.0JJ - $3,450.00
17 x 9.0JJ - $3,550.00
17 x 10.0JJ - $3,650.00
18 x 7.5JJ - $3,900.00
18 x 8.0JJ - $3,950.00
18 x 8.5JJ - $4,000.00
18 x 9.0JJ - $4,050.00
18 x 9.5JJ - $4,100.00
18 x 10.0JJ - $4,150.00
19 x 8.0JJ - $4,500.00
19 x 8.5JJ - $4,550.00
19 x 9.0JJ - $4,600.00
19 x 9.5JJ - $4,650.00
19 x 10.0JJ - $4,700.00
20 x 8.5JJ - $5,050.00
20 x 9.5JJ - $5,150.00
20 x 10.5JJ - $5,250.00
The price is for the following color: Black, white, Bronze and Silver dish with white spokes.
Chrome is at another price. Just to let u know the price different.
18 x7.5JJ $3900.00 (for color mentioned above) and the price for the chrome is $4700.00 for the same rims.
I would recommend getting the silver instead
  • Replies 43
 Share
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
    • You need the kit turbo taipan has shown you because that manifold ia designed have side feed injectors
