Im dropping the price to $25000 or i will negotiate a better price with out a roadworthy.
1992 R32 GTR 96000kms Factory Grey colour, body in vgc as is the interior.
3 inch cat back exhaust with hi flow cat,
please note there will not be any test drives unless a deposit has been put down.
Im looking at $25k pm or email [email protected]
https://www.sau.com.au/forums/topic/64274-eoi-r32-gtr/
Can you please tell us a bit more about the car to help interstate people a bit more?
Scratches or dents? Has the car been in any accidents? Resprayed?
Compression tested the engine? Leak down?
etc?
https://www.sau.com.au/forums/topic/64274-eoi-r32-gtr/#findComment-1227087
etc?
The body is in vgc, had the roof sprayed as it had some dents on it, the previous owner reckons he didnt have a garage and and some branches etc would have fallen on the car as he lived neat the bush.
No dent to think of a few littke scratches on the front bar.
Ive been meaning to compression test the engine at work just have to get around to it.
No leak down test performed as i have neved had the car at a mechanics.
https://www.sau.com.au/forums/topic/64274-eoi-r32-gtr/#findComment-1227118
Thanks for that mate...
Would probably help interstate buyers a lot if you could do the compression test and swing by a panel beater and ask them if it's been in any accidents...
Would make the decision to fly over to Melbourne that much easier if those two factors were known :D
https://www.sau.com.au/forums/topic/64274-eoi-r32-gtr/#findComment-1227191
thanks for the pointers merli,
il do a comp test next weekend as im the keenest to known how the engine is
When i had the roof done my panel beated did check it over and said the only think he seen was the front bar was replaced and it had a aftermarket fibreglass one on it.
my guess is as good as anyone elses to work out what happened to the bar.
https://www.sau.com.au/forums/topic/64274-eoi-r32-gtr/#findComment-1227795
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
