Hi.
What functions can I access with the dagalogit that I can't access with just the handcontroller?
I don't think that's the point of the datalogit... The point is have you tryed to setup a whole fuel map or ignition map using the hand controller? The datalogit allows you to setup the whole map at once instead of having to view the map in sections like you do on the hand controller. It just makes tuning a lot easier vs. the hand controller. I'm sure there are other uses for it but i believe that is one of the main reasons people use it.
https://www.sau.com.au/forums/topic/64327-fc-datalogit/#findComment-1205816
Advice--
Go to the FC-Datalogit website, this IS all explained..
There are some settings like temperature settings that can't be fully set with the hand controller, instead with FC-Datalogit, you can drop these values.. FC Commander can drop the fan turn on tmep to 95 deg, where as with FCDatalogit you can go below 70 deg.
You can also hook up launch control for 0 km/h rev limiting.
Go to the website it is all answered, all explained..
https://www.sau.com.au/forums/topic/64327-fc-datalogit/#findComment-1206446
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
    • Here's a pic of the damn thing
